Old 01-04-2006, 10:07 PM   #1 (permalink)
Mr. B's Avatar
New Axle Seal Installed
Just to let ya'll know, while I was putting my new wheels on, I noticed that the right rear wheel had oil on the inside of the rim. I remove my wheels and clean the backsides about every three months ( I know....OCD..) so it was a "fresh" leak. I took it to David McDavid Nissan in Houston and they replaced the seal, bearing and a spacer. They also had 3 Qrts. of syn. lube on the repair ticket. My truck has 55k miles on it. The service writer tried to tell me that Mobile 1 rear end lube probably caused the seal failure, and then called me later that day and tried to tell me that because the rear cover had been removed and re-sealed, the warrantee was void. I have not removed the rear cover but I have painted the rear-end, frame and suspention gloss black...( OCD again) He finally backed down and fixed it under warantee but acted like he was doing me a secret favor. What a Bozo.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 01-05-2006, 05:52 AM   #2 (permalink)
Re: New Axle Seal Installed
"The service writer tried to tell me that Mobile 1 rear end lube probably caused the seal failure, and then called me later that day and tried to tell me that because the rear cover had been removed and re-sealed, the warrantee was void."
Did he have any black eyes or choke marks on his neck? Just wondering how often he pulls stuff like that.
Old 01-05-2006, 07:38 PM   #3 (permalink)
Mr. B's Avatar
Come to think about it, I think his calm demeaner and gentle, soothing voice almost had me convinced that he was right. Does Nissan teach their service writers how to hypnotize their pray?
Old 01-06-2006, 08:37 AM   #4 (permalink)
Banned
TitanFan59's Avatar
Actually he was trained by Geico, coming next was he had just saved 15% by switching to Geico.
TitanFan59 is offline   Reply With Quote
is your Rear axle seal Leaking Stomper4x4 Titan General Discussion 9 12-06-2005 08:25 AM
Rear Axle seal failures Wiscdave Titan Problems & Dealer Service 4 11-22-2005 06:12 AM
How do you tell if a axle seal is leaking Wiscdave Titan Problems & Dealer Service 10 11-16-2005 02:34 PM
Another leaking Axle Seal?? 54warrior Titan Problems & Dealer Service 7 11-14-2005 03:20 PM
Rear Axle Seal Leaking?? JimB Titan General Discussion 15 10-11-2005 06:50 PM
