Old 02-13-2006, 08:53 PM   #1 (permalink)
Toxman's Avatar
Send a message via ICQ to Toxman
Front differential oil
What oil should I use in the front differential? Do you have to use standard 80W-90 or could you used a synthetic like Mobil 1 75W-90?
Toxman is offline   Reply With Quote
Old 05-17-2006, 03:27 PM   #2 (permalink)
Re: Front differential oil
I was wondering the same thing....
titanse05 is offline   Reply With Quote
Old 05-17-2006, 08:28 PM   #3 (permalink)
racefan92307's Avatar
Send a message via Yahoo to racefan92307
i'm running mobil 1 75w90 with no problems. also mobil 1 75w140 in the rear and mobil 1 5w30 truck and suv motor oil.
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
HELLWIG REAR SWAY BAR
LED TAILLAMPS
RANCHO RS 9000 SHOCKS
racefan92307 is offline   Reply With Quote
Old 05-19-2006, 03:11 PM   #4 (permalink)
Toxman's Avatar
I did the same. You could use 75W-140 in the front also but it probably isn't needed. BTW, mine was low from the factory. You might want to change your tranfer case fluid too. Mine was low there as well.
2004 Titan CC LE - Born 10/04
Mods:
  1. Westin Bull Bar
  2. Flowmaster Exhaust
  3. 2" leveling Kit
  4. K&N drop in filter with stock air box mod
  5. BF Goodrich 315/70/R17 T/A AT KO tires
  6. Active Tuning grounding kit
  7. Under seat storage bin
  8. Silver Star Halogen Headlights
  9. Nissan Sliding tool box
Old 05-20-2006, 10:32 PM   #5 (permalink)
Titan1080's Avatar
Nissan still specs 80w90 for the front I believe.
AKA, Rusty Whore™
2004 Titan XE KC 4x4 DOB 12-15-2003
Compare your truck to mine and then kill yourselves!
Titan1080 is offline   Reply With Quote
Old 05-21-2006, 01:35 AM   #6 (permalink)
Toxman's Avatar
Right. 75W-140 would give you greater heat range but really isn't required for the front. The 75W-140 Cost too much anyway!!! :-)
Mods:
  1. Westin Bull Bar
  3. 2" leveling Kit
Front Differential Fluid Change L.A.FIREMAN Titan General Discussion 22 07-20-2009 04:06 PM
Front Differential Problem w/ NO help from NISSAN AlaskanTitan Titan Problems & Dealer Service 14 01-03-2006 10:58 AM
Front Differential *Update* CincyTitan Titan Problems & Dealer Service 9 02-25-2005 01:19 PM
Front differential oil change? bradw Titan Engine, Transmission & Drivetrain 4 02-08-2005 09:17 PM
Front Differential Housing supergoat65 Titan Problems & Dealer Service 20 06-02-2004 08:23 AM
