Old 03-06-2006, 11:22 AM   #1 (permalink)
shaffer's Avatar
'04 rearend - finned diff vs. new axle
Looks like I'm the lucky recipient of a dying rear end. My '04 Titan just turned 30,000 miles. While changing a flat tire the other week I noticed the diff cover was completely rusted form top to bottom and the paint was gone. The diff was also leaking. I took it into the dealership last week to look at a couple of items which included the rearend. When I went to Sutherlin Nissan I honestly expected them to tell me this is normal and just deal with it (they like to tell me that). When they called to tell me the that the entire rearend has to be replaced and they ordered a new axle seembly I was impressed. I was glad to hear the axle will be replaced, but surprised it has lasted 30,000 miles. I do a fair amount of towing with my truck, pulling a CJ-7 to places like North Carolina and Alabama from Atlanta. You'd think it would of died out log before now.
I read another thread on this site that talks about Titan owners having their rusted diff covers replaced by Nissan dealerships, switching them to the finned version found on '05s and up (not switching out the entire axle). Is this just the dealership putting a band-aid on a bigger issue? After reading all of the stories about rearends blowing up, I would not be comfortable with just a new diff cover to solve the problem. When so much heat is generated by the R&P that the paint peels of the diff cover, a finned cover isn't going to fix the damage already done internally.
I looked over the Dana 44 yesterday and was unable to find a vent hose on the pumpkin. Surely I just overlooked it and Nissan is intelligent enough to properly vent their axles - otherwise just about every Titan out there that pulls in the 5,000 - 6,000 lb range will eventually lose their rearend to heat!
What's my point? I hope those people who are getting their diff covers replaced aren't getting the smoke and mirrors treatment from Nissan.
shaffer is offline   Reply With Quote
Old 03-06-2006, 11:33 AM   #2 (permalink)
Re: '04 rearend - finned diff vs. new axle
The vent is a check valve that sticks up on the right side of the rear axle assembly (not on the pumpkin or close to the pumpkin).
Old 03-06-2006, 11:40 AM   #3 (permalink)
helomech's Avatar
Maybe when they were trying to seal the rearend they may have noticed some broken gears, and aren't telling you. I doubt they would have change the rear if they didn't have to. If it wasn't broken the dealer would have to eat the cost because nissan would not reimburse them. I just posted some pics of the diff vent in the thread below this one.
helomech is online now   Reply With Quote
Old 03-06-2006, 02:00 PM   #4 (permalink)
shaffer's Avatar
Why would the vent not be on the pumpkin since that is where a majority of the heat is generated? That doesn't make sense. The seals to the left and right of the carrier prevent the heat from exiting the pumpkin. The heat does not escape left and right down the axle tubes. Maybe that's the problem - the vent is not properly located.
Old 03-06-2006, 02:03 PM   #5 (permalink)
Sammy Sandbag's Avatar
Vents aren't for heat, they are for the pressure that builds as a result of the heat. The axles are sealed at the ends of the tubes, not inside the carrier. There's nothing really wrong with their placement, as long as they are working properly.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 03-06-2006, 02:34 PM   #6 (permalink)
shaffer's Avatar
I believe they are sealed at the chunk as well. Otherwise your diff fluid would run into the axle tubes during any off camber run. If you look at any other dana 44/60/70 they are vented at the pumpkin.
Is the pressure not generated from heat buildup?
Old 03-06-2006, 02:42 PM   #7 (permalink)
I see what you're saying, but I've also seen axles that carry fluid in the tubes. Seems sorta pointless to have a vent there otherwise and seals at the ends as well. Now front axles are usually the way way you describe.
Symantics. The vent isn't there to release "heat" but air pressure as a direct result of heat.
-Counsel Yourself
Old 03-06-2006, 02:43 PM   #8 (permalink)
shaffer's Avatar
Disregard the heat/pressure question. You won't have one without the other. The vent allows the heat to escape, thus keeping the pressure in check.
I'm not trying to be difficult with this. I just have a hard time understanding why the vent isn't in the more logical location - on the pumpkin.
Old 03-06-2006, 02:51 PM   #9 (permalink)
Well except the heat is still present. The heat is created by the friction between the gears, not the friction between air molecules.
Your guess is as good as mine.
-Counsel Yourself
Old 03-06-2006, 06:02 PM   #10 (permalink)
ptgarcia's Avatar
The vent is there to bleed pressure, not release heat.
If the axle is pressurized it doesn't matter where the vent is placed because all points inside the axle will have equal pressure.
Pauly
Old 03-15-2006, 02:17 PM   #11 (permalink)
shaffer's Avatar
I just spoke with my Nissan dealer. Looks like it is going to be a couple more weeks before my new Dana 44 arrives. According to the service rep the axles assemblies are on "national backorder." Apparently the problem is big enough to drain Nissan's supply!
Old 03-15-2006, 03:05 PM   #12 (permalink)
RB's Titan's Avatar
Part of the problem maybe that Dana has filed for bankruptcy.
http://www.detnews.com/apps/pbcs.dll...603040330/1148
Randy
IRC CREW CHIEF - International Racing Club VK56
MODS: PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, RB Custom Ram Air, RB 170 Thermostat, Volant G1 CAI, Stillen Headers, RB Custom B-Pipe w/Cats in line, Custom Banks Exhaust, Father of Titan UpRev Tunes, JWT Cams, Detroit TruTrac LSD, N20, lol
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 03-15-2006, 11:40 PM   #13 (permalink)
the rear end not properly vented would cause leaks the problem with our diffs at these low mileages you see posted is the fact that the spider gears are made out of a composite metal instead of solid steal bad idea i have a 65 dodge dart gt put a big block in it the first time i jumped on it i did the same thing that happened to the diff in my truck known problem with the 7and3/4 inch chrysler diff of the past COMPOSITE GEARS
autotech is offline   Reply With Quote
Old 03-17-2006, 08:25 PM   #14 (permalink)
Smoke05's Avatar
Leaks lead to low fluid levels, which leads to higher heat in the diff, which can contribute to weakening the spider gears. I'm sure the powdered metal process and it's apparent lack of QC consistency from Dana isn't helping either.
Smoke05 is offline   Reply With Quote
Axle Wrap and Rear Diff chung_chang Titan Suspension 7 12-31-2005 10:38 AM
Titan Rear Diff Finned Cover 6thsense Titan Parts & Accessories 2 05-02-2005 02:44 PM
Finned diff cover gasket question... DaveS Titan General Discussion 4 03-29-2005 04:17 PM
New aluminum finned diff. cover on Ebay... HudsonValleyTitan Titan General Discussion 14 03-08-2005 05:35 PM
05 finned rear diff cover for my 04 is HERE!! gr8titan Titan General Discussion 22 03-01-2005 09:35 AM
