I just changed out my rear diff. to Mobil 1 75w140, but didn't think about the front. Should you change them at the same time? Or at different intervals (front does not need to be changed as much) Also can I use the mobil 1 75w90?? Thanks in advance.
2006 Granite 4x4 LE Kingcab with Offroad package, Big Tow Package, and Power Captains.
If you off road any or go through water deeper than the bottom of the diff, you need to check both front and rear diffs for water.
There is a vent tube that should keep pressure equal. If that gets clogged or does not function properly, you can have a vacuum inside the diff which will suck water into it if you get into deeper stuff.
It's always a good idea to check each diff after going into more than 8 inches of water or so. If you took water, it will turn the diff fluid milky and will come out the inspection (top) hole of the diff when you unscrew it.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Thanks for the heads up.
