Old 03-19-2006, 01:48 PM   #1 (permalink)
racefan92307's Avatar
Send a message via Yahoo to racefan92307
Exclamation serviced rear diff today little surprised
after reading all the post rear diff failures, decided to service it. was a little surprised at the condition of the fluid,was dark, dark gray. the drain plug had about a 1/4 of fuzzy metal debris on it. little dissapointed to have spent the kind of money on this truck and have to service the diff at 5000 miles.is it just the way it's built by dana? poor quality control? or is it a cheap diff. bought this truck to tow my deck boat. better not start having issues or will condiser replacing it with a different truck, maybe go back to a chevy.
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
HELLWIG REAR SWAY BAR
LED TAILLAMPS
RANCHO RS 9000 SHOCKS
racefan92307 is offline   Reply With Quote
Old 03-19-2006, 01:54 PM   #2 (permalink)
Mr. B's Avatar
Re: serviced rear diff today little surprised
Sounds to me like yours was 10x cleaner than mine....I had to remove my rear cover and chisel the lube out with an ice-pick.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 03-19-2006, 02:21 PM   #3 (permalink)
Burly's Avatar
Any rear new rear diff will have metal pieces in it, that is part of the break in policy. Just because many rear diffs have failed, does not mean yours will. Go back to a Chevy and service the rear diff in that one and you will find the same thing.
Had..
05 Titan SE 4x4
Color: Blizzard
Crew Cab
Have..
Burly is offline   Reply With Quote
Old 03-19-2006, 02:58 PM   #4 (permalink)
Toxman's Avatar
Send a message via ICQ to Toxman
Originally Posted by racefan92307
after reading all the post rear diff failures, decided to service it. was a little surprised at the condition of the fluid,was dark, dark gray. the drain plug had about a 1/4 of metal debris on it. little dissapointed to have spent the kind of money on this truck and have to service the diff at 5000 miles.is it just the way it's built by dana? poor quality control? or is it a cheap diff. bought this truck to tow my deck boat. better not start having issues or will condiser replacing it with a different truck, maybe go back to a chevy
I think this may be normal break-in. Mine was gray also at around 7000 miles. It is probably gray due to the metalic particles in oil. I had lube and metal particles on the plug also. I changed over to Mobil 1 75W-140 and have checked it numerous times since (up to 8000 miles now) and it looks as good as the day I added it.
Toxman is offline   Reply With Quote
Old 03-19-2006, 03:15 PM   #5 (permalink)
Bear Hunter's Avatar
Ok... lets clear some things up here...because people are gonna be confused when they read this unless it is clearly defined.
Metal Shavings & Metal Pieces are NOT normal
Normal wear will look like "fuzzy metal debris" it will be very very fine in consistency and will collect on the magnet.
"fuzzy" metallic particles on the magnetic drain plug is normal wear. If you notice any larger chips of metal on the magnetic portion of the plug, such as "shavings" or metal "pieces" you need to drop the pan and have a qualified individual fully inspect the internals.
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Truck Toyz Performance
Special Thanks to: Trucktoyzperformance, Rize Industries, Autometer, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, and DC Customs
Bear Hunter is offline   Reply With Quote
Old 03-19-2006, 03:36 PM   #6 (permalink)
revised my post with fuzzy metal debris on the drain plug. thanks bear hunter that was a valid point. i didn't mean to suggest there were chunks of metal on the drain plug.
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
LED TAILLAMPS
Old 03-19-2006, 03:37 PM   #7 (permalink)
bbomar's Avatar
How much 75w-140 does the diff hold? 2 quarts I have heard but would like a difinate. Thanks for any help.
Old 03-19-2006, 03:55 PM   #8 (permalink)
i used about 2 1/4 qts of mobil 1 75w-140. going to do the front diff next weekend any idea on how much it takes? going to put mobil one in the front also
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
LED TAILLAMPS
Old 03-19-2006, 04:07 PM   #9 (permalink)
Burly's Avatar
Your exactly right. I should have included that small crucial part in my post.
Had..
05 Titan SE 4x4
Color: Blizzard
Crew Cab
Have..
Old 03-19-2006, 04:48 PM   #10 (permalink)
steve83's Avatar
I got 22K miles on my diff(04), with the factory oil still in it. I figure if the diff is gonna blow, its gonna blow. IMO a diff is gonna blow because it is a POS, not because of the diff oil(assuming proper level).
steve83 is offline   Reply With Quote
Old 03-20-2006, 02:47 AM   #11 (permalink)
Banned
why are you doing this at 5K miles? thats a waste of money. especially in the front where there are no problems.
mach1 is offline   Reply With Quote
Old 03-20-2006, 07:37 AM   #12 (permalink)
want to go to 85w90 mobil1 synthetic. just to check for fuzzy debris, make sure its full. just to make me feel better
05 4X4 LE
BIG TOW
BLIZZARD WHITE
ACTIVE GROUND KIT
BILLET GRILLE
AVS BUG SHIELD
LAZER LITE TONNEAU
LED TAILLAMPS
Old 03-20-2006, 09:00 AM   #13 (permalink)
Banned
If you want to see if its full, pull the fill plug and stick your finger in it. hell, you might as well change the tranny fulid while your at it going by your logic.
Old 03-21-2006, 08:48 AM   #14 (permalink)
cynic05's Avatar
Well if you ask me it makes sense to change it, I did. Just to be sure you have synthetic in it and the correct weight oil! I'm sorry but I don't trust Nissan to have put the correct weight/type fluid in during all the changes and problems their having. My fluid was very dark and metallic as well and not to mention it was very thin. The 75/140 I put in was way thicker at the same temp!
cynic05 is offline   Reply With Quote
Old 03-21-2006, 09:23 AM   #15 (permalink)
Banned
You have an 06? And u had the wrong oil in it from the factory fill? Interesting. Doubtful, but interesting. If thats the case, we can all sue Nissan and get this taken care of. I guess youll never be able to prove it though.
rear diff CurtiSue Titan Engine, Transmission & Drivetrain 18 11-24-2005 11:54 AM
Had the oil and rear diff. fluid changed today. Flight Test Titan Engine, Transmission & Drivetrain 7 08-03-2005 11:47 AM
Changed the rear diff oil today cttitan Titan Engine, Transmission & Drivetrain 10 04-12-2005 11:29 AM
Changed the front diff oil today (pics attached) cttitan Titan Engine, Transmission & Drivetrain 5 04-06-2005 08:13 PM
Test drove three diff exhaust systems today 04LX Titan Performance Modifications 23 08-08-2004 07:09 AM
