Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Truetrac in Titan - Review - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 03-24-2006, 01:13 PM   #46
Justintoxicated
Justintoxicated's Avatar
Re: Truetrac in Titan - Review
How would this thing work in sand dunes? From what I have sceen Real Lockers work the best in sand I don't thnk I would want the power transfer constanly going to be shifting back and fourth between the rear tires and I would best like to have an equal amount of pull from both sides in any sticky situation.
Old 03-24-2006, 01:25 PM   #47
bestatchess
http://www.landyonline.co.za/techtal...onversions.htm
The stuff about sand is at the bottom. But no, don't buy one, at least until I get mine.
Old 03-24-2006, 01:31 PM   #48
shaffer
shaffer's Avatar
If you want constant power to both wheels in the sand, a full Detroit or ARB is the way to go. If you are using your truck strictly as a trail vehicle, you'd save some cash by running a full spool. Sand dunes are not something you'll find in North Georgia, but from what I've read in magazines, I believe wide tires are good for sand - you need a lot of floatation, and they'll give you that. Interco/Super Swampers might be your best bet (Boggers), if you can live with a short tread life.
shaffer is offline   Reply With Quote
Old 03-24-2006, 02:06 PM   #49
Chris93Si
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Great info Austin! Just getting in here so I'll remember to check for updates
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 03-24-2006, 02:33 PM   #50
markislive78
markislive78's Avatar
Nice link...Thanks
markislive78 is offline   Reply With Quote
Old 03-24-2006, 02:48 PM   #51
1bigtexastitan
1bigtexastitan's Avatar
One pithy question Austin?
Will Detroit offer one for the front diff as well?
I am sure to get the one for the rear but I would also want one for the front as well...making it a "true" 4X4.
Thanks again for the info and review...
2005 Galaxy Crew Cab SE 4x4 With Big Tow, Rockford Fosgate, Utilitrack System
Mods:
De-Badged
35% Front Tint
Sylvania Silverstars All Around
OEM Foglight Kit
Active Tuning Ground Kit
OEM Rubber Mats
Magnaflow True Dual Custom Exhaust with X-Pipe
1bigtexastitan is offline   Reply With Quote
Old 03-24-2006, 04:55 PM   #52
Armada
Armada's Avatar
Austin, thank you for being the laboratory test bed for this. Not only have you helped us find a really good solution to traction problems, but I believe you are dead on right about this solving the diff weakness problem.
Like you, I have seen and played with the guts of a lot of diffs. Our axles are incredibly beefy for a 1/2 ton truck, and the size of the teeth on the ring and pinion are more than stout enough. By keeping the actual diff ratios down to 2.92 or 3.36 and gearing low in the tranny, you get a much bigger pinion gear than if this was a 4.10 rear end.
Many of us here have felt that the diff failures were due to spider gear problems. The TrueTrac replaces them. TrueTracs can and do take a lot of horsepower on the strip and are tried and true.
Now, Nissan, if you are listening (or reading), why don't you learn from this and just put a TrueTrac in the rear of each of your '07's when they come out and have some happy customers and save a ton of money on warranty work?
Problem solved. Thanks, Austin.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 03-24-2006, 05:21 PM   #53
Austin
Austin's Avatar
Originally Posted by Mike H.
Do you have the "burnout mod"? If so, that would be a great test.
All you need to do is pull off the connector above the brake pedal - and yes, I've done that before... to spin circles in a dirt field with the OEM diff locked.
I will hopefully be able to convince my beautiful cameraperson to make some video this weekend. Oh, and I'll also ask her to get some video of a 2 wheel burnout on dry pavement.
MY04 SE King Cab 4X4 SOLD!
Old 03-24-2006, 05:58 PM   #54
pi3yeargrad
pi3yeargrad's Avatar
did u take any pics of the tru-trac itself? Or of the install?
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 03-24-2006, 06:00 PM   #55
QShip
QShip's Avatar
Austin, thanks again for all of your hard work.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 03-24-2006, 06:03 PM   #56
bestatchess
I think O4DRunner has a TruTrac pic in his gallery.
Old 03-24-2006, 09:48 PM   #57
37L1
37L1's Avatar
OK, OK, Ok, will this mod cause a problem with those equipped with VDC???
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 03-24-2006, 09:53 PM   #58
got_titan
got_titan's Avatar
from my understanding......no....i have one on order from a friend so as soon as its released ill be first in line........
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 03-24-2006, 09:57 PM   #59
37L1
37L1's Avatar
Oh, oh, oh, oh, I see one of these in my future. . . .
I'm definitely going to have to check out your Titan when I'm back in your neighborhood.
Got a good place that's going to install this for you?
Old 03-24-2006, 10:00 PM   #60
got_titan
got_titan's Avatar
yes.....i actually have a good friend that works for nissan that will install for about 150-200......cant wait to get 2 wheel burnouts......
User Name
Password
JDM HID for Titan Review Elbo Titan Parts & Accessories 126 06-18-2008 01:38 AM
Picture of Detroit Truetrac limited slip (available for us in 05') markislive78 Titan Engine, Transmission & Drivetrain 4 01-11-2005 07:30 PM
SEMA TrueTrac locker NOT Available pciley Titan Performance Modifications 1 12-23-2004 10:22 AM
JP Magazine Titan Review Sammy Sandbag Titan General Discussion 6 06-05-2004 08:08 PM
titan review smoketitan Titan General Discussion 1 06-04-2004 01:40 PM
Search this Thread:
Advanced Search
vB code is On
