Old 04-02-2006, 12:10 PM   #1 (permalink)
transfer case refill
I want to change the fluid in the transfer case. I don't want to pay Nissan prices for Nissan ATF. What can I substitute for Nissan ATF without voiding the warranty?
Patrick Dennis is offline   Reply With Quote
Old 04-02-2006, 01:05 PM   #2 (permalink)
helomech's Avatar
Re: transfer case refill
Dexron III, Mercon or equivalant may be used. According to the service manual.
Old 04-02-2006, 06:37 PM   #3 (permalink)
CV Titan's Avatar
The manual says you can use Dexron III or Mercon. I used Dexron when I discovered mine was leaking. I found 2 loose bolts towards the top of the transfer case. I leaked about .7 qt.
CV Titan is offline   Reply With Quote
What about the transfer case fluid? setitan Titan General Discussion 11 04-02-2006 12:50 PM
Transfer case leaking? tillery444 Titan Engine, Transmission & Drivetrain 3 03-23-2006 12:52 PM
Transfer Case?? 20TITAN04 Titan General Discussion 16 02-25-2006 09:44 AM
New diff and transfer case kljp Titan General Discussion 12 12-23-2005 05:04 PM
Transfer case.. vector6 Titan Engine, Transmission & Drivetrain 2 12-21-2004 02:20 PM
