2010 rear DIff blew😡😡 - Nissan Titan Forum
post #1 of 7 (permalink) Old 06-16-2017, 03:34 PM Thread Starter
6"sexytitan's Avatar
iTrader Score: 0 reviews
Ok so DIff basically went boom on me ,I'm a newb kinda with Nissan DIff n gearing ect ,my problem is ,truck has used warrantee and it's in a shop ,they have searched coast to coast for a used DIff and none avalible anywhere in the gearbratio I have 3.356.shops don't want to rebuild it here either?!only Nissan dealer has for 5000 new😳I asked mechanic if he could just used a different ratio like 2.94 ect and he said no because it has to be what stoxk is to match transfer case and front DIff,is he right or wrong ,I think u could why not .my warrantee will cover 3000 max so trying to see what I can do
6"sexytitan is offline
The Following User Says Thank You to 6"sexytitan For This Useful Post:
phi021 (06-16-2017)
Advertisement
post #2 of 7 (permalink) Old 06-16-2017, 04:23 PM
FishnAlaska's Avatar
Garage
iTrader Score: 3 reviews
Re: 2010 rear DIff blew😡😡
He is right, it has to be a 3.36 gear if that was the OEM gear. Different gearing between front end and back end will not work, they have to be turning at the same speed or one of them is going to explode.
2010 Titan 4x4 CC SE Majestic Blue
Uprev tuned by Seymore, JBA Evol catback, Cajun catless B pipes, Airaid MXP 4" CAI
8" Boston acoustic's sub in Tech12volts ported box w 1000 w renegade amp
Autostart remote start, bedlined OEM wheels, bumpers, and grill. Go Rhino D2 steps.
Pyramid Automotive Retro fit headlights with Xenonvision H1 Hid's and super bright LED reverse lights, blue interior LED's, and white exterior LED's.
Smoke hood shield and in channel window deflectors, Custom grounding kit by FAK.
Pro4X skid plate, 20" double row Cree light bar, rear bumper flushmount Cree LED's
Leer 100R Topper, Goodyear Duratracs 275/70/18,
Dirt King UCA's, Bilstein 5100's mid setting and 1.5" spacer, 1.5" rear block w/Bilstein 5125's.
FishnAlaska is offline
post #3 of 7 (permalink) Old 06-18-2017, 09:06 AM
I don't believe they can't find a rear axle anywhere because they can be found on car-part.com and for under 3000 too. And as mentioned, they need to look for the axle in 3.36 ratio.
malleusdei321 is offline
post #4 of 7 (permalink) Old 06-19-2017, 09:46 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
Check with JustDifferentials.com.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #5 of 7 (permalink) Old 06-20-2017, 12:03 PM Thread Starter
Yes I found them aswell on car-parts.com thanks ,there having it sent to a 4x4 shop to hopefully rebuild it,one question is there any way to tell if I have elect locker??when I put my vin in it says I do but garage says no as there's no harness or sensor going to DIff?
post #6 of 7 (permalink) Old 06-20-2017, 12:39 PM
HRTKD's Avatar
Garage
If you have the e-locker there will be a button on the dash, usually low next to the VDC button if you have it.
HRTKD is offline
post #7 of 7 (permalink) Old 06-20-2017, 01:16 PM
This is so easy - like others mentioned car-parts.com - call the junk yard directly and confirm the axle is in stock and request pictures be sent to your cell phone. if the axle is in great shape, you may even see the sticker on the side that confirms the 3.36 gear ratio.
I have done this every time and get pics via text from junk yard finds all the time. if the part looks good, then confirm local shipping quotes, freight shipping using companies like YRC freight, and other companies.
It's best to find a freight company in your city, then confirm that the same company services the city where the part is located and thus you can have something freight shipped from YRC city X to YRC of city Y.
I did this to avoid shipping doc fee's, etc.
I live in San Antonio, TX and had a e-locker axel shipped to me from el paso TX junk yard - axle i found using car-parts. this was for my Nissan xterra axle.
Thanks,
-J
Jasontamu is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Just blew up 2nd rear diff.. This is crazy!! Doc Steve Titan General Discussion 35 09-12-2014 10:27 PM
Blew rear diff 73k jaywith05LE Titan Engine, Transmission & Drivetrain 8 08-30-2012 02:18 PM
Convert 2010 Rear Diff to 2004, Last Check? CrazyHorse89 Titan Engine, Transmission & Drivetrain 14 12-03-2010 06:57 AM
Blew Front Diff. white_titan05 Titan Engine, Transmission & Drivetrain 8 12-23-2007 10:03 PM
i think i just blew out my rear diff???? titanrookie Titan General Discussion 38 01-25-2007 04:43 PM
You may post new threads
You may post replies
