Hello fellow TitanTalkers...
I've been doing a series of tests over the last ten tanks of gas in an effort to find out where the mileage peak is on my particular Titan.
Test conditons: Mixed city/highway driving during the same commute to work, same errands every week, same meetings at church; all drives by the same driver. No racing. No 'FY-Buddy' roar-aways. Fuel is the same brand, from the same station, all the same octane - 87. The weather has been very regular lately, with no great variations so that factor is fortunately fairly level. Highway tests were conducted over a series of long drives to family events, fuel still bought at the same place.
Truck is a very early '04, non-tow with standard paper air filter but custom exhaust (FM50, dual in-single out with 3" pipe). Tires are Continental 10 ply, at 5 PSI above door sticker recommendation. Oils are synthetic engine, standard Nissan J-Matic trans and transfer, synthetic diffys; all at recommended weights and levels.
Tester's notes: Many engines have a 'sweet spot' where everything all comes together. This particular engine's good spot was at about 2350. Yours of course will be different, depending upon mods, etc.
I found that I could signficantly increase the fuel mileage by just getting COMPLETELY off the gas about a block or so before a full stop. Experimentation has revealed that the optimum distance is about a block and a half on my truck. Also, I used the technique I learned a long time ago with a VW beetle I owned: Get to speed quickly, then get off the gas just enough to maintain speed.
One thing also helped, and that was to keep the pedal depressed at a constant level. Small accelerations cost in fuel. Collorary for the Titan: Make cool exhaust sound, pay at pump.
Gathering the 3000 RPM data was difficult, as many idiots thought I was racing them. Wait until next time, you guys...
Anyway, I hope this helps. I'll check back a few times and answer any questions.
