Old 05-18-2006, 12:32 AM   #1 (permalink)
Coolant leakage
Anyone ever smell that sweet odor of coolant after a ride, especially up steep inclines? I've always had this and found a slight leak between the metal and plastic joint on the radiator. No loss in fluid, but the smell concerns me.
Stranger is offline   Reply With Quote
Old 05-18-2006, 09:40 PM   #2 (permalink)
TitanTech659's Avatar
Re: Coolant leakage
They have the same problem with the Altima radiators. The top seams leak coolant. You should probably take it in and get it replaced before it gets worse and leaves you stranded or it overheats and damages the engine.
TitanTech659 is offline   Reply With Quote
Old 05-18-2006, 09:52 PM   #3 (permalink)
Rookie's Avatar
Re: Coolant leakage
Mine started leaking at about 50,000 miles. I tried to have it replace under the powertrain warranty, with no luck. Get it fixed. Mine went from a scent, to a dribble, to a leak in two weeks.
Rookie is offline   Reply With Quote
Coolant Smell? Big Azz Rice Burner Titan Problems & Dealer Service 5 03-15-2006 01:50 PM
Antifreeze Coolant? pImpNaTitaN Titan Engine, Transmission & Drivetrain 1 11-01-2005 08:34 PM
Anyone know the best way to drain coolant? doctor steve Titan Parts & Accessories 2 10-09-2005 07:04 PM
Do you have water leakage with your cover? Mike Up Titan Parts & Accessories 0 04-25-2005 07:01 PM
