I just installed a Volant CAI 3 days ago today while driving on highway and city streets my trans was delaying gear changes and slamming to gear! Any input and could it be related to the CAI?
check to be sure the cone filter and tubes are secured. I fellow titan owner I know had some weird bogging on his stock truck because 1 of the clips to hold down the top casing wasn't locked.
also check to make sure the MAP sensor is properly connected (dont know where it is, havent looked at my truck much, only had it 2 weeks) but the map tells computer about engine load and if it gets false readings it will probably shft when it gets to a preset speed or redline or maybe not at all..
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Did you get the MAF(Mass Air Flow) sensor hooked back up? My Ford Ranger would shift just like you described if I pulled off the MAF connector....and it wouldn't set a code for a VERY long time!
PRG Performance Kit w/SAW's
Born 9/2004
