Old 06-14-2006, 07:16 PM   #1 (permalink)
silverbeast's Avatar
Question transfer case fluid...
has anyone change the oil on the transfer case yet? can we use something other than nissan fluid? because i would like to try the something from amsoil.
**06 TITAN CC SE 4X4 BIGTOW**
**FLOW MASTER**
silverbeast is offline   Reply With Quote
Old 06-14-2006, 08:38 PM   #2 (permalink)
Toxman's Avatar
Send a message via ICQ to Toxman
Re: transfer case fluid...
Yes you can. BTW, it's transmission fluid in the transfer case. Nissan Matic D or any Dexron III or Mercon ATF will do (see attached). I used Mobil-1 synthetic ATF. Works great! Be sure to place your drain pan back a bit from the drain plug because it throws a mean stream!
2004 Titan CC LE - Born 10/04
Mods:
  1. Westin Bull Bar
  2. Flowmaster Exhaust
  3. 2" leveling Kit
  4. K&N drop in filter with stock air box mod
  5. BF Goodrich 315/70/R17 T/A AT KO tires
  6. Active Tuning grounding kit
  7. Under seat storage bin
  8. Silver Star Halogen Headlights
  9. Nissan Sliding tool box
Toxman is offline   Reply With Quote
Old 06-14-2006, 09:02 PM   #3 (permalink)
Wildmike's Avatar
I have been running Amsoil ATF in the transfer for 6 months now. Good stuff.
WildMike
2006 4WD KC SE w/ BT
Fram Boost CAI
Custom 3" Magnaflow exhaust
http://media.putfile.com/Titan-0-85 2/15/06
http://media.putfile.com/Nissan-Titan-on-Dyno 8/17/07
Wildmike is offline   Reply With Quote
Old 06-14-2006, 10:21 PM   #4 (permalink)
got_titan's Avatar
amsoil atf in my t-case....agree! great stuff!
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 06-15-2006, 05:35 AM   #5 (permalink)
Send a message via Yahoo to Cajunguy
Originally Posted by Toxman
...... Be sure to place your drain pan back a bit from the drain plug because it throws a mean stream!
Sure wish I had read this before last Saturday - DOH
M1 ATF for me as well in the transfer case.
'04 Titan Galaxy LE KC 4x4
Off Road & Big Tow Packages
Build Date: 06/14/04
Buy Date: 06/25/04
Wade In-channel Vent Visors
PRG's Front Leveling Kit
P/A 3" Body Lift Kit
Bushwacker Fender Flares
Billet Grille
MagnaFlow Single Side Exit
Nitto Dune Grappler A/T (315/70/17)
Firestone RideRite Airbags
Cajunguy is offline   Reply With Quote
Old 06-15-2006, 12:07 PM   #6 (permalink)
hwyking's Avatar
Same here. I just changed mine the other night. Initial stream overshot the funnel and then when it started started going in the funnel I dropped the drain plug in there and clogged it Good thing I put down a big piece of cardboard. No oil on the driveway, just all over my arm and clothes
I just used some Napa house brand dexron III ATF I already had in my garage. Switching to Amsoil ATF later.
05 LE CC, 4x4, BT, OR, Nav
hwyking is offline   Reply With Quote
Old 06-15-2006, 03:01 PM   #7 (permalink)
alright, i'll put the oil pan a little further. i plan on doing the transfer case this weekend with amsoil atf. i'll be sure to hold on to the drain bolt though. 1 3/4 quarts, right? anyone of you take more than that? just wondering.
**FLOW MASTER**
Old 06-15-2006, 08:46 PM   #8 (permalink)
hwyking's Avatar
I used about 2.5 qts.
What about the transfer case fluid? setitan Titan General Discussion 11 04-02-2006 11:50 AM
Transfer Case?? 20TITAN04 Titan General Discussion 16 02-25-2006 08:44 AM
New diff and transfer case kljp Titan General Discussion 12 12-23-2005 04:04 PM
diff and transfer case fluid question tccart Titan General Discussion 7 08-23-2005 10:19 PM
Transfer case.. vector6 Titan Engine, Transmission & Drivetrain 2 12-21-2004 01:20 PM
