Old 06-19-2006, 03:30 PM   #1 (permalink)
StuntDriver06's Avatar
Lightbulb Technical Info about VK56DE?
i was wondering if anyone had any technical info on the motor in the titan... i have a desktop dyno program and wanted to try to plug in some of the info to see what the curve would look like and see how accurate it is, but i cant seem to find info anywhere.. all i got is like compression ratio and bore/stroke.. I need things like cam angles (when intake valve opens/closes, same for exhaust) and valve lift @ what type of timing, and cfm of stock TB (and aftermarket ones if possible) oh and also valve sizes.. and any other info anyone can provide would be great... thanks alot
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 06-20-2006, 08:04 AM   #2 (permalink)
QWIKWHIP's Avatar
Re: Technical Info about VK56DE?
Just sent you an email of the VK56 Tech Sheet to the address in your sig.
Old 07-21-2006, 05:06 PM   #3 (permalink)
no one has anything else?
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 07-21-2006, 06:00 PM   #4 (permalink)
loufish's Avatar
I have Desktop Dyno 2000, and started a file on our engine, but like you I'm looking for the same info...The fact sheet I have doesn't give me cam timing info either...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 07-22-2006, 07:35 PM   #5 (permalink)
TitanBlue's Avatar
Can someone post what you do have. Lots of curious owners, even if minimal data.
Thanks
Old 08-09-2006, 09:55 AM   #6 (permalink)
Armada's Avatar
Try this attachment.
It is the paper that Nissan engineers submitted to the Society of Automotive Engineers (SAE). They have purposefully blurred some of the detailed specs., so I can't help that. But there is a ton of information in this paper.
BTW, what I now say is intended to be constructive, and I say this with care and concern. I have posted this paper at least three previous times. I would urge those seeking information to please try the search function. It is easy and quick and avoids having to reinvent the wheel each time. There is a lot of good information we can all get without having someone else have to go dig it out for us. I mean no offense, and hope you find this paper useful.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 08-09-2006, 09:58 AM   #7 (permalink)
1bigtexastitan's Avatar
linky no work.....
2005 Galaxy Crew Cab SE 4x4 With Big Tow, Rockford Fosgate, Utilitrack System
Mods:
De-Badged
35% Front Tint
Sylvania Silverstars All Around
OEM Foglight Kit
Active Tuning Ground Kit
OEM Rubber Mats
Magnaflow True Dual Custom Exhaust with X-Pipe
1bigtexastitan is offline   Reply With Quote
Old 08-09-2006, 10:00 AM   #8 (permalink)
Nevermind, you edited something and now it works.........
Mods:
De-Badged
35% Front Tint
OEM Foglight Kit
OEM Rubber Mats
Old 08-09-2006, 10:02 AM   #9 (permalink)
Armada's Avatar
Yeah, I had the file name wrong and had to correct it. Sorry.
Galaxy Black
Old 08-09-2006, 08:40 PM   #10 (permalink)
QShip's Avatar
Thanks for the sheet!
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 08-14-2006, 06:41 PM   #11 (permalink)
have searched.. info not anywhere to be found... maybe no one know cept engine designers so far... your link is very useful, however it doesn't have the info i am looking for... Thanks
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 08-14-2006, 07:04 PM   #12 (permalink)
MuskyHunter's Avatar
What specific information are you looking for?
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage
www.secretlake.net
Old 08-14-2006, 07:05 PM   #13 (permalink)
read first post.... ty
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 08-19-2006, 08:42 PM   #14 (permalink)
Mczarski's Avatar
Wow, I didn't know it was basically a Q45 engine bored out, that is a very reliable engine, however also very expensive to replace. The Q45 engine used alot of the Infiniti Racing engine mechanicals. I had a 1993 Q45, loved doing burnouts in that thing.
Mczarski is offline   Reply With Quote
Old 08-20-2006, 08:23 AM   #15 (permalink)
ummmmmm... nvm deleted post
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Is the vk56de 4 or 6 Bolt main? vuaccordla Titan General Discussion 5 08-27-2005 08:14 PM
Nissan performance mag shot of VK56DE BIGT56PA Titan Engine, Transmission & Drivetrain 4 01-10-2005 01:20 PM
What was this technical writer smoking? Bayou Titan Titan General Discussion 3 12-27-2004 08:55 PM
Factory Technical Rep says still problems with brakes after new TSB Chemist2000 Titan Wheels, Tires & Brakes 22 11-21-2004 05:56 AM
Titan Technical Service Manual ??? bestatchess Titan General Discussion 17 02-16-2004 05:39 PM
