Old 06-21-2006, 05:58 AM   #1 (permalink)
New Rear Diff Oil Before or After Tow?
I'm planning to take my '05 Titan out for its first big tow next week. The truck currently has about 6500 miles on it and my travel trailer is about 4000 lbs. I'm getting my oil changed and tires rotated a few days before the trip and was thinking of giving the rear differential its first fluid change at the same time.
At a cost of $80 for the change, do you think it is really needed?
If so, would it be best to change the fluid before or after my 500 mile trip?
Thanks
meltingpoint is offline   Reply With Quote
Old 06-21-2006, 06:22 AM   #2 (permalink)
sudden urge's Avatar
Re: New Rear Diff Oil Before or After Tow?
If I were to change it, I would do it after the tow since you have low mileage. Personally, I have no intentions of changing the differental oil and will follow the owners manual schedule. If the rear fails, it will be Nissans problem imo.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
Old 06-21-2006, 07:30 AM   #3 (permalink)
I would definitely change the diff. oil before you tow. In fact I would have have changed the oil sooner.Many of us on this board change the diff. oil at 5k or less. You may be surprised at how dirty the oil is.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 06-21-2006, 07:42 AM   #4 (permalink)
$80? wow . . . or you could just pick up a few bottles of mobil1's gear oil that everyone here is using and do it yourself, saving you around $50 (if you only do the rear) and giving you the peace of mind of it being done. just my $.02.
04 Red Brawn CC 4x4, OR + BT
Mods:
Banks, AEM Brute Force, Icon (rear)
Modified CB with Firestik mount
Rocky Mounts bike-utility rack mod
Still in box:
PRG mini-lift
spidy is offline   Reply With Quote
Old 06-21-2006, 08:51 AM   #5 (permalink)
I changed mine out at 1000 miles and then again at 5000 and 15000. Per the recommendation of my dealer I will be changing out the oil every 10000. I believe that the rear ends are going out for other reasons other then the weak spider gears. I think that it is due to heat and oil break down. imo.
jaimr is offline   Reply With Quote
Old 06-21-2006, 08:51 AM   #6 (permalink)
If the gears are a bad design or flawed, why waste any money trying to prolong the inevitable.
Old 06-21-2006, 09:06 AM   #7 (permalink)
You are assuming that the gears are a flawed. What if it is not a gear problem but a heat issue?
Old 06-21-2006, 09:12 AM   #8 (permalink)
You can say what if all day long. The fact is the oil will not mask a heat problem or any other problem. The owners manual clearly states what and when fluids are to be changed.
Old 06-21-2006, 11:06 AM   #9 (permalink)
Whether the diff. is flawed etc. is not the point. It is good to change the oil on any diff.,tranny, motor etc. after a few thousand miles to get the debris from manufacturing etc. out. This will help insure the longevity of your trucks parts regardless of the make, brand or model.
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
Old 06-21-2006, 12:09 PM   #10 (permalink)
How about I change the question a bit.
Let's say that I want to change the rear diff oil soon. Would it be more beneficial to change it before I tow this trailer for 500 miles, or after?
BTW, here are some more details about the truck, in case it matters. It is a 2005 SE King Cab 4x2 with Big Tow, Utility Bed, and Trac (Limited Slip) packages.
Old 06-21-2006, 12:18 PM   #11 (permalink)
Change it before you tow. The purpose of the oil it to lubricate and cool the rear gears. While towing you are putting extra stress on the rear and fresh oil is always better then old.
Old 06-21-2006, 01:41 PM   #12 (permalink)
Do someting better for the rear by adding traction springs. For $80 this greatly reduces rock and axle wrap, therefore helping the whole rear drivetrain. I still say leave the oil in there and follow the owners manual. Spend that $80 on something like I just mentioned.
Old 06-21-2006, 08:21 PM   #13 (permalink)
It would be wise to change it before you go. I also would change it after you tow that many miles for the first time. I have got 7500 miles on my truck and tow a camper 4500lbs about every 4-5 weeks on 100 - 200 mile trips. I have changed my oil 3 times, plus I just changed it after my 1800 mile trip pulling a small 5' x 8' trailer last week. The rearend runs hot when towing and breaks down oil quick.
Ramon is offline   Reply With Quote
Old 06-26-2006, 02:49 PM   #14 (permalink)
vegashd's Avatar
considering the Dana 44 axle is found in other vehicles with NO problems or heat issues, what would you say the nautre of the failures be?
vegashd is offline   Reply With Quote
Old 06-26-2006, 03:01 PM   #15 (permalink)
In itty bitty Jeeps with itty bitty tow ratings.
Not 1st, Not 2nd, But 3rd rear diff :) jserman Titan Engine, Transmission & Drivetrain 12 04-06-2006 11:14 PM
rear diff CurtiSue Titan Engine, Transmission & Drivetrain 18 11-24-2005 11:54 AM
Changes for 06 Rear Diff Austin Titan General Discussion 3 10-26-2005 07:48 AM
Rear Diff. rogerhrt Titan Engine, Transmission & Drivetrain 8 08-03-2005 10:03 AM
rear diff tobz Titan Engine, Transmission & Drivetrain 5 07-28-2004 09:39 AM
