Old 07-06-2006, 05:05 PM   #1 (permalink)
P0455 and P0222 codes?? Help!!!!
p0455 and p0222 error codes???
04 Titan
Driving on the highway and the B-LSD light came on and engine and transmission went into safe mode. Was able to limp it to a dealer and these are the code that popped. They are wanting to replace the throttle body and vent control valve for $1100($775 for parts). The truck has 51000 miles and is out of warranty. I feel like I am being ripped off.
Any info would be greatly appreciated.
Thanks in advance
Jed
jrauch is offline   Reply With Quote
Old 07-06-2006, 06:37 PM   #2 (permalink)
SOCALTITANKC4X4LE's Avatar
Re: P0455 and P0222 codes?? Help!!!!
Here is what the Nissan Service Manual describes for P0222
The electric throttle control actuator consists of the Throttle Control Motor, and Throttle Position Sensor which tells the ECM the info it needs to to control the Throttle Control Motor to make the throttle valve opening angle properly in responce to driving conditions.
Listed possible cause of P0222: Bad Harness or Connectors, Throttle Position Sensor 1 circuit is open or shorted, or bad TP Sensor, or Bad Electric Throttle Control Actuator.
Accelerator Pedal Position sensor 2 cicuit is shorted, Bad APP Sensor.
IN Safe Mode, The ECM regulates the opening speed of the throttle valve to be slower than in Normal Mode, so acceleration will be slower.
2005 Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b][color="Blue"]BLUE LED DASH LIGHTS MOD
1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads [b][color="Red"]487,000 miles and I'm hoping to get 500,000.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 07-06-2006, 06:42 PM   #3 (permalink)
For P0455 :
EVAP canister purge volume control soleniod valve circuit shorted. Bad EVAP canister purge volume control soleniod valve.
Old 07-06-2006, 10:33 PM   #4 (permalink)
baseballfanz's Avatar
I got the P0455 one time for not closing the gas cap. there's a leak either with the cap or somewhere in the EVAP system
P0222
Throttle/Petal Position Sensor/Switch B Circuit Low Input
http://www.troublecodes.net/OBD2/Pcodes.shtml
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 07-07-2006, 04:17 AM   #5 (permalink)
thanks so much for the info. I am going to get a new gas cap and hopefully clear the one code. I talked to a former Nissan tech and he said the p0455 code will pop sometimes if you fill your gas tank while your engine is running as well.
As for the throttle body problem it sounds like I may have to lump that.
Thanks again for all the help
jed
Old 07-07-2006, 04:20 AM   #6 (permalink)
Shouldn't that be covered under the powertrain warranty. I thought the powertrain warranty went was 60,000 or 70,000 miles.
KYDeepwater is offline   Reply With Quote
Old 07-07-2006, 04:37 AM   #7 (permalink)
bbomar's Avatar
There is also an emissions warranty. I think it's 80,000, check into that. I think is required here in KY.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Old 07-07-2006, 04:47 AM   #8 (permalink)
Good point! The emmisions warranty is regulated by the fed's. All parts covered are listed in warranty info.
04 White SE, CC, 4x4,BT,POP/Capt.,Util. Bed package,Mud Guards,Floor Mats. Born on April Fools Day. Gas Whore.
Remember; Electrical wiring is no hobby.
electricjohn is offline   Reply With Quote
Old 07-11-2006, 02:03 PM   #9 (permalink)
checked warranty and this does not seem to be covered. My luck!!!
Thanks for the info though
Old 07-11-2006, 02:23 PM   #10 (permalink)
Throttle body = $473.96
Vent Control Solenoid = $68.74
www.nissanpartscheap.com
diagnostic codes andy biro Titan Engine, Transmission & Drivetrain 11 06-16-2006 06:53 PM
EVAP - Control Valve SES code P0455 phlydude Titan General Discussion 3 10-18-2005 07:20 PM
SES lighted up then disappeared - no codes rcantu Titan Problems & Dealer Service 4 09-22-2005 03:06 PM
RF Radio and amp color codes. 05Titan05 Titan Visual & Audio Discussion 1 08-01-2005 08:30 PM
