Old 07-22-2006, 08:54 AM   #1 (permalink)
Wallrat's Avatar
lifted-now getting squeek from front diff
I installed a PC 6" lift a few months back and everything was fine. A couple weeks ago I started getting a squeeky noise on hard right turns only. I tried to identify where it was coming from without any luck. Now the squeek has expanded to also being quietly present anywhere over 50-60mph. I'm not talking about a mild squeek either. Its a prolonged metal rubbing sound.
I pulled the front wheels and checked the hub nuts which were still good at 105 ft/lbs. But when I turned the hubs by hand I found that I had an occasional squeek coming from where the right cv goes into the front diff. I'm guessing this has to be it. Its definately rubbing metal somewhere which blows.
Prior to doing anything else, I just wanted to see if anyone had heard of this or knew of a cause.
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
Wallrat is offline   Reply With Quote
Remove front sway bar on lifted Titan, Yes or NO? K-MU Titan Suspension 59 12-26-2007 04:34 PM
Nissan not replacing Rear diff on Lifted trucks???? jserman Titan Engine, Transmission & Drivetrain 31 04-30-2006 01:06 AM
Another front diff gone! KTMNealio Titan Engine, Transmission & Drivetrain 12 02-23-2006 06:19 PM
? front diff MIKEY Titan General Discussion 7 10-18-2005 03:37 PM
