Old 07-28-2006, 12:40 PM   #1 (permalink)
Rear Dif Fluid Change Question
Can anyone advise me if it would be alright to use teflon tape on the rear dif plug threads when I close it up. I have some on hand. Or do I need another product?
Thanks to all in advance.
12glocks is offline   Reply With Quote
Old 07-28-2006, 01:18 PM   #2 (permalink)
Mr. B's Avatar
Re: Rear Dif Fluid Change Question
I didn't use anything on the threads when I buttoned mine up....come to think of it, I never have and I've changed rearend oil many, many times over the years....If you want to use it I don't think it would hurt anything.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 07-28-2006, 01:22 PM   #3 (permalink)
Use an RTV sealer such as Permatex. The tape may not be the best thing to use especially as hot as the rear can get when towing.
XRING600 is offline   Reply With Quote
Old 07-28-2006, 01:54 PM   #4 (permalink)
Use Permatex High Performance Thread Sealant
or Permatex High Temperature Thread Sealant
should be available at locat auto parts store.
Old 07-28-2006, 02:13 PM   #5 (permalink)
I know from experience that Teflon tape and petroleum products don't mix. Especially when you heat and pressure.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 07-28-2006, 02:24 PM   #6 (permalink)
Thanks you very much gentlemen for your responses. While I suspect Mr B is correct: no harm will come, I noticed it has a compound on the thread from the factory. Being a bit of a perfectionist, i will look for the high temp version.
Thanks again.
Old 07-28-2006, 02:47 PM   #7 (permalink)
SOCALTITANKC4X4LE's Avatar
There is no need to put thread sealant on the diff. plug. The gear oil is not pressureized.
2005 Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b][color="Blue"]BLUE LED DASH LIGHTS MOD
1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads [b][color="Red"]487,000 miles and I'm hoping to get 500,000.
SOCALTITANKC4X4LE is offline   Reply With Quote
15,000 Mile Rear Diff Fluid Change SmokenMini Titan Engine, Transmission & Drivetrain 2 03-23-2006 09:03 AM
Rear diff. fluid change pics admorris Titan Engine, Transmission & Drivetrain 64 11-11-2005 10:40 PM
Brake Fluid Change Titan4x4Aggie Titan Wheels, Tires & Brakes 5 05-06-2005 05:51 PM
Rear Diff fluid question...HELP!! VShortt Titan General Discussion 6 03-02-2005 11:27 AM
Question on replacing rear diff fluid Half Shovel Titan General Discussion 34 12-02-2004 07:00 AM
