Has anyone been successful in coverting their 2wd Titan into a 4wd?
If you have where did you get your parts, and what parts did you use?
I am exploring my options. I want to be 4wd now and don't really want to buy another truck since I already have so much into mine and it would be a shame to lose my @ss and have to start all over again. I love my truck but I found a reason to have 4wd now, C.O.R.R. Recon team. Any suggestions would be highly appreciated. Thanks.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
a lot of money either way. I would try a trutrac first.
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
Salvage Titan on Ebay for sale. Take the parts needed off of it. Then salvage the rest of it off for parts to sell. Looks like it may be a 4X4
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
I think you would need to buy an ECU that is programmed for 4X4. Besides all the obvious mechanical parts.
__________________ Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
I've heard some rumors of an aftermarket way of setting it up where you don't need the stock computer changed. Think about the guys doing solid axle swaps, same difference, they pretty much strip everything stock off and put a whole new front end on.
Mods to date:
I knew a guy who turn his 4x2 into a 4x4, he took it into the dealer and traded it in.
Nice one.
Mods to date:
But they also already have the correct ECU, the TCU, and the 4x4 main harness. Yes, the entire main harness is different between the two. You'd be better off trading, and probably cheaper as well.
The factory ecu wont control aftermarket parts.
If I trade it in I will lose big. $34,000 invested with truck, tax, lift, tires, wheels, cover,ect. Figure about $18,000 for trade in. New XE 4wd with big tow $29,200 + tax, lift, tires, wheels,ect. Even if it were 4,000 I'd be better off.
Mods to date:
Go with trutrac and a longtravel front setup.. you said it was for CORR, right?? if you want to make a rockcrawler out of it, then get a set of Dana 60's (front and rear) and swap them both out, and find a totalled Titan that would have the trans with the Xfer case on it.
But if you just want a normal 4x4, trade it in....
I'm not sure what you mean here. I agree with the others; either get a trutrac if you need the traction, trade for a 4WD, or just use your truck in situations that don't require 4WD.
FWIW, I was in a similar boat as you a while ago. I had orders to Colorado, with only a 2WD truck. Of course this was before the Trutrac was released. I did some pretty hefty research into the required parts, and their prices used and new. It's just not feasible to do a conversion.
Not really a conversion from to 4x2->4x4 but Four Wheeler's Mega Titan has a Dynatrac 60 up front. The whole project looks incredibly expensive though...
Hey man, so are you admitting that Kenny was right? Are 4wd titans better at the CORR recon thing? LOL
Aqua, I just figured out how to switch from 2 to 4wd. There is a selector switch to the right side of the steering column, you just turn it to 2,4H or 4L it's easy!
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
[/img]
-[/img]
Hey Aqua, this is what it looks like..... Check it out, it's really user friendly!
