Old 08-10-2006, 09:26 AM   #1 (permalink)
beached_titan's Avatar
harsh downshift to 2nd
the other day iwas coming down a hill so i used my manual shift mode to downshift and engine brake my truck. i shifted down to 2nd at about 30mph and my truck shook so violently i thought my wheels were falling off or something. ive noticed slight vibration when shifting down to 2nd for a while now actually since ive had it lifted. but the other day was the first time that it shook the entire truck. so just wondering if anyone else has had this experience? maybe its because of the bigger tires? im running 35's on my truck... i dont know, im clueless. i want to take it in to the dealer but im afraid of getting the "well, its modified" speach again.
beached_titan is offline   Reply With Quote
Old 08-10-2006, 09:42 AM   #2 (permalink)
Send a message via AIM to galaxycrew
Re: harsh downshift to 2nd
no its me too. i guess it could be because of the larger tires, as i have 35's too i've just gotten much more accustomed to downshifting to 2nd when going at a much slower speed (25-30mph).
galaxycrew is offline   Reply With Quote
Old 08-10-2006, 10:18 AM   #3 (permalink)
wow, thats a comfort... i guess... ive never experienced anything like this in any other lifted truck. guess i just wont downshift to that gear lol
thanks for the reply
Old 08-14-2006, 03:55 PM   #4 (permalink)
hmmm just from reading other posts, im thinkin this might also be axle wrap when im downshifting... any thoughts?
Old 08-14-2006, 04:22 PM   #5 (permalink)
SOCALTITANKC4X4LE's Avatar
This is no need to manually down shift to 2nd, unless you are going down hill and you are trying to prevent your brakes from heating up. And you are going 20 mph or less. Your truck shook because you shifted down too soon. From 4rth to 3rd, you won't feel it, but 3rd to 2nd is a big drop.
Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 08-14-2006, 05:16 PM   #6 (permalink)
shifting down to 2nd at 30mph is too fast? it does it even worse at 27mph...
i dont think speed is the issue, the manual says that if the vehicle speed is too high for the gear being selected, then it will not downshift into that gear. i can shift down to 1st at 22mph and get no vibration at all.
and yes i need as much braking help as possible, this one section of a freeway here that i take home everyday has a 15% downgrade and traffic ALWAYS builds up at the bottom of the hill. being that i have 35's, i dont really feel like glazing and warping the hell out of my rotors.
edit: i see you live in riverside, so ill tell you. coming down the 241 to the 91 at 5:45pm. you know how traffic builds up on that hill all of a sudden. and if im cruising at 70mph and see brake lights, i start downshifting to slow this beast down!!
Old 08-14-2006, 06:20 PM   #7 (permalink)
StuntDriver06's Avatar
its not too fast, the titan tranny brain is trying to make all shifts as smooth as possible, which it accomplishes by allowing slippage between the clutches between shifts... bigger tires, hills, higher heat can all play a factor as to how much slippage occurs, and the vibration you feel is most likely the clutches trying to engage....
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 08-14-2006, 09:01 PM   #8 (permalink)
edit: i see you live in riverside, so ill tell you. coming down the 241 to the 91 at 5:45pm. you know how traffic builds up on that hill all of a sudden. and if im cruising at 70mph and see brake lights, i start downshifting to slow this beast down!![/quote]
I understand about the going downhill on the 241. I would just anticipate the slow down and just drive slower as you approach the 91. No matter what, you're going to have slow down, because you can't fight the traffic. Why put more load on your tranny and brakes?
Old 08-14-2006, 09:33 PM   #9 (permalink)
hey beached titan...what kind of lift do you have? i have the procomp stage1 with 35" bfg at's. i too have axle wrap, and yes this may be the cause of the vibration. i have had the carrier bearing drop kit installed, but this only slightly fixed the problem. to completely eliminate the axle wrap, i plan on a full deaver pack + prg traction bars.
Old 08-14-2006, 10:54 PM   #10 (permalink)
Yellomantis's Avatar
this was happening on my 04 that I had. It was bone stock though. It felt like the whole truck was juddering as it dropped into the lower gear. It never went away. I don't have the problem on my 06 as of yet. But I only have 3500 miles on it too.
www.myspace.com/yellomantis
Old 08-14-2006, 11:37 PM   #11 (permalink)
Banned
SilverQShip's Avatar
I've found a slighty different problem. The other day we were cruising at a reletively slow speed (50) and we had to get around this car so my dad kinda put the hammer down. THe revs got to 6200 rpm and there wasnt that much of a pull but on the upshift it felt like we got rearended. THe truck reared and took off.
-Son fo SQS
SilverQShip is offline   Reply With Quote
Old 08-15-2006, 07:20 AM   #12 (permalink)
possible, but when it literally feels like the transmission just dropped out the bottom of the truck i kind of get the feeling its more than clutches trying to engage
it never did it until i got the lift. i have the cst 8" with the stock leaf's..
i cant get the deaver packs, as i tow with my truck and cant afford airbags to go with it. i dont know if deaver makes a leaf pack now that can handle weight? maybe ill have to get prg's traction bars.
Old 08-15-2006, 07:26 AM   #13 (permalink)
shawnwat4's Avatar
Send a message via AIM to shawnwat4
mine has no lift on it, and it will do the same when i downshift from 3rd to 2nd. i'm kinda relieved to see its not just me
GO Pirates- STEELERS- Penguins
2004 Blk Titan SE KC 4x4 w/ Off Road pkg, Nismo CAI, Flowmaster rear exit dual exhaust, LT285/70/17 BFG Mud Terrains, RF pkg, custom box w/ 2 Diamond 10" Subs, Precision grill, stainless steel nerf bars, utilibed pkg, fog lights,
future mods: tinted front windows, 2" PRG mini lift, Bilstien shock upgrades, Westin Bull Bar
aka. The Dirty Whore
shawnwat4 is offline   Reply With Quote
Old 08-15-2006, 05:02 PM   #14 (permalink)
cluthces are the only part of the tranny taht engage/disengage... the bigger tires and whatnot is probably putting a bigger strain on the tranny... dunno just my opinion....
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Old 08-15-2006, 05:11 PM   #15 (permalink)
Doesnt the CST kit come with rear blocks? If so, It might be bad axle wrap.
Surprise Downshift on Flat road spoonman Titan Engine, Transmission & Drivetrain 6 09-15-2006 07:34 PM
Street Ride too harsh on 305/45/22's. Need Smoother Shock Advice bgash Titan Suspension 5 06-30-2006 08:14 AM
Very Harsh LOUD Noise on acceleration Wes3 Titan Engine, Transmission & Drivetrain 15 10-27-2005 05:23 PM
tranny 'shudder' @ 3-2 downshift mtofell Titan General Discussion 9 01-25-2005 09:39 AM
ok to downshift? dilleyoshemp Titan General Discussion 34 12-24-2004 02:08 PM
