Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Rear axle seals leaks. Please report. - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 08-07-2007, 09:23 AM   #151
Helinut1970
Re: Rear axle seals leaks. Please report.
Originally Posted by keane
Looks like my Rear Passanger seal is leaking - it was in two weeks ago for an oil change and to get my bed bolts and spacers fixed and they didn't notice it. Hope it is covered by the PT warranty as I am over the 36 moth one.
Should be covered under the warranty. If they say it isnt just go to a different dealer.
Now Gone but still Love em----------------07 2500 HD silverado 4 door
Old 08-08-2007, 05:27 AM   #152
XXX_Titan
XXX_Titan's Avatar
I just blew both axle seals at 25,000 miles. I know they just blew cause I towed about 10-11K lbs this weekend for about 30 miles. Then I noticed a oil spot on my garage floor. Easily noticable casue its a brand new house.
2005 CC-LE 4x4
Toyo Open Country A/T's 305/50-20
MKW M44 20x9
PRG 2" Front, 1" Rear
XXX_Titan is offline   Reply With Quote
Old 08-08-2007, 05:29 AM   #153
roy365
roy365's Avatar
Have already had driver side replaced.......just looked under my truck this weekend and noticed the passenger side is blown now!!!!!! ARRRGH!!!!
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Cams, Uprev tuned, Headers, Volant CAI & Exhaust, Race cats........etc.
roy365 is offline   Reply With Quote
Old 08-09-2007, 09:30 PM   #154
AMCS
Took my 04 KC LE OR BT in for 30k service. I had noticed some oil drops from the engine area on my garage floor. Service manager called me back and said the fromt diff pinon seal and right rear axle seal were leaking. He stated the axle seal must have just started leaking. Both seals were replaced under warrenty and they also replaced the axle bearing. Had to leave the truck overnight for the work to be completed. Had a Sentra loaner for the night. No hassles from the dealer, just great service.
AMCS is offline   Reply With Quote
Old 08-10-2007, 01:13 PM   #155
bestatchess
Originally Posted by RB's Titan
Could it be the vent tube not venting correctly do to over fills duirng diff oil changes?
I think vent failure may indeed be the case. If the check valve gets plugged, I think the axle seals handle the venting. The people who replaced the diff vent check valve with a vent hose with a fuel filter on the end don't seem to be blowing axle seals.
Old 08-11-2007, 09:24 AM   #156
import2nr
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
where can i see the mod at... is there a link and parts list and a how to write up on it .... if so, can someone point me in the right direction?
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*Two 10" Kicker Comp's down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Knock off AEM CAI
*AIRE TBS
*2 Degree Timing advance(thanks to Chung at UpRev)
*JBA Muffler and 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
import2nr is offline   Reply With Quote
Old 08-15-2007, 09:46 PM   #157
RB's Titan
RB's Titan's Avatar
ha ha mine failed again same side they just replaced...4000miles ago. geez this is stupid.
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 08-17-2007, 01:27 PM   #158
VQ56DEPOWER
VQ56DEPOWER's Avatar
Hey I am new here. Had my Titan since 04. had no problems till now. My left rear axle is leaking. I have 61K miles on it. Noticed when i was changing the rear deff oil. Want to know if anyone fixed it by them selfs or not. have not called the dealer yet, and I dont know if they will fix it under warrenty. And ill report it to NHTSA
Thank
VQ56DEPOWER is offline   Reply With Quote
Old 08-17-2007, 01:34 PM   #159
Ourbaby
Ourbaby's Avatar
Not up on this one myself but Welcome to TT and someone will help you.
Ourbaby is offline   Reply With Quote
Old 08-20-2007, 05:54 AM   #160
KYDeepwater
My passsenger side seal was leaking in June, they told me it was due to overfilling the diff. I told him I don't think that is right and I would keep an eye on it. Well, Friday at 59,952 miles, I noticed it was leaking quite a bit. Went straight to the dealer and had the receipt from June with their comments. He scheduled me for this Wednesday. The left one is wet, I'm going to take a photo of both sides and try to convince them the left one will leak soon and hopefully they will fix it also. Does the vent filter get clogged with oil and stick? Or does it get hot and stick? Should it be cleaned regularly to prevent build-up or just do the mod with vent hose to prevent further problems?
KYDeepwater is offline   Reply With Quote
Old 08-21-2007, 03:02 PM   #161
jd1973
Left was leaking on my 04 at 53k. Went to dealer and he just replaced rear end-didn't even ask.
Seems easy enough.
JD
jd1973 is offline   Reply With Quote
Old 08-22-2007, 04:56 AM   #162
KYDeepwater
Has anyone had seals replaced with paperwork showing that new seals are now being used? There was a mention that an upgraded seal was in use, and I want to see if this is true and if anyone has part numbers so I can check when they replace mine tomorrow.
Old 08-23-2007, 08:33 AM   #163
spyderwebb
spyderwebb's Avatar
Mine is in the shop today for bad exhaust manifold on right side and leaking rear differential cover, and as I was looking underneath I see that both rear axles are leaking on to brake covers, bottom half completely saturated.
Dealer advised he will cover it, can't beleive they didn't see it when looking at rear end. Anyway, I reported to the Gov sight as sugested in this thread and we'll see how the repairs go.
It seems the Titans are plagued with problems, I've had the truck for three years and have had a dozen problems, from brakes to transfer case, to leaking AC, to odd ticking noices and now these issues.
spyderwebb is offline   Reply With Quote
Old 08-29-2007, 01:11 PM   #164
scorpion12
Just found this thread the other day, discovered that both rear axle seals were leaking at 37,000 miles or so. Right one was leaking onto the brake rotor; left one was just seeping. Neither were bad enough to leave oil on the driveway.
Called the dealer, dropped it off Sunday, both seals replaced Monday. I'm thinking of doing the axle vent mod and being done with it. I'm not sure I want to run as much hose into the body as was mentioned in the other thread though. I'm thinking just a good 2 feet or so should be fine with a filter on the end.
scorpion12 is offline   Reply With Quote
Old 09-01-2007, 09:42 PM   #165
admw12
When I first bought my 06 CC I registered with this forum. It was right away I read about the problems with the rear diff. To avoid any complications, I replaced the diff cover with a larger one that holds 4 quarts of gear oil and has a dip stick for easy fluid checks. Last week I found a driver side seal leak and was wondering if the new diff cover voided my warranty? I am afraid to go in and ask. Has anyone else had any problems with getting this fixed under warranty with a aftermarket diff cover?
admw12 is offline   Reply With Quote
User Name
Password
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 03:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 08:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 09:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 02:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 05:18 AM
Search this Thread:
Advanced Search
vB code is On
