Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Rear axle seals leaks. Please report. - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 01-14-2008, 06:33 PM   #211
BRKTRCR
BRKTRCR's Avatar
Re: Rear axle seals leaks. Please report.
sorry, forgot truck info for those keepin track...
2005 KC LE 4X4 BT OR UB Red Brawn
Mods:
Extang Tuff Tonno,Volant,Sirius.
BRKTRCR is offline   Reply With Quote
Old 01-25-2008, 07:58 PM   #212
wanatitan
wanatitan's Avatar
Hi all! I'm new here!
I just bought a used 05 titan with 23000 miles on her. I just found this thread tonight so I have not checked the rear end yet.
I was wondering if anyone has taken pics of their vent mod yet.
If not I think it would be a wonderful thing for someone that has done the mod to post the pics with ""how to" directions. I know I would appreciate it. It sounds like a great mod. But unsure how to go about it.
What filter are you using, and where are you running the hose??
I would do this in a heart beat
wanatitan is offline   Reply With Quote
Old 01-25-2008, 08:24 PM   #213
bestatchess
Toyota part #9040451026
3/16" fuel line
1/4" to 5/8" range hose clamps
FF2314 G6529 fuel filter
Everything from Autozone except the Toyota fitting (threads match perfectly).
http://www.titantalk.com/forums/tita...ghlight=toyota
Old 01-25-2008, 08:49 PM   #214
wanatitan
wanatitan's Avatar
Thank you so much for the quick reply! I guess Ill be climbing under my truck tomorrow. Thanks again
Old 01-26-2008, 11:54 AM   #215
wanatitan
wanatitan's Avatar
Red face Re: Rear axle seals leaks. Please report.
Well I went through the SHAME of going to toyota to buy toyota parts to fix my titan.
Gotta do what ya gotta do!! They had to order it.
I did check the diff fluid and found it low.
I too took off the check cap and had a rush of vacuum when I removed the filler plug! I drove to work Let the truck sit about 3 hours before the check!
My other concern is- Ive read on this fourm people say the book says the rear end fluid is suppose to be 80-90 gl5. Lots of you are putting mobil 1 synthetic 75-90. Well when I climbed under my titan, the differential cover is stamped "USE 75-140 SYNTHETIC OIL ONLY!"
Is this a replacement axle???
Well let me know what ya think!
I think I should use whats stamped right on the axle!!!
Old 01-26-2008, 12:00 PM   #216
bestatchess
Use only 75-140 synthetic for the rear diff.
Old 01-29-2008, 08:18 PM   #217
wanatitan
wanatitan's Avatar
Well Guys add me to the axle vent mod. I hope that keeps my axle from leaking.
Lovin this web site. Thanks bestatchess for the quick reply and posting those pics again for me. It was very easy. Also the original vent that was on the axle was rusted closed!!!! I could not even blow thru it.
Old 02-05-2008, 09:40 AM   #218
BK19702
BK19702's Avatar
I had the passenger side rear axle seal replaced yesterday under warranty. I noticed the leak on Sunday while doing other maintenance under the truck (good thing too!). Driver side is ok at the moment (knock wood). Anyway, reported with the NHTSA today:
Your Complaint Information is successfully submitted.
Your Confirmation number (ODI Number) is: 10216983
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 02-09-2008, 06:16 PM   #219
nellup3
nellup3's Avatar
My breaks started squeaking so I checked them out and found i had a rear axle seal failure. So when I got home Checked my dads and found that bout of his were leaking. We both have 05's I have 48k and he has 72k. I sumitted both of our trucks to the site.
Mods
Westin Brush gaurd and low profile tool box
Huskey floor mats
K&N intake
6' Procomp Lift
Flowmaster exhaust
35' Nitto Mud Grapplers
20' Black Moto Metals
nellup3 is offline   Reply With Quote
Old 02-14-2008, 07:01 PM   #220
Masa
Masa's Avatar
Another possible reason for the seal failures
My '06 had 3 rear axle seal failures before the differential failed and had the entire rear-end replaced. The other day, a Nissan shop foreman told me that the reason why the seals were failing was because the drive shafts within the rear axle was not thick enough and caused too much twisting motion, resulting in too much stress on the seals causing premature failures. According to him, the new rear-ends, including my replacemt has beefier shafts to prevent this from occuring. I have not seen this piece of info. on this forum before, and I have no clue as to the credibility of what he told me. However, he was speaking with confidence.
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Masa is offline   Reply With Quote
Old 02-24-2008, 05:38 PM   #221
bfit01
Had mine replaced a couple months ago. Then on the drive home "CLUNK, CLUNK!!" Dealer ended up replacing the whole rear end at 42k.
bfit01 is offline   Reply With Quote
Old 03-03-2008, 01:08 PM   #222
TitanRider
TitanRider's Avatar
I believe my axle seal is bad at 47k miles. Changed the oil a month ago in the diff and the the backside of the rotor shield has more oil on it. It also thuds from D to R and back to D and there is some play in the driver shaft. Taking it to the dealer today. Should I have them rebuild the whole thing?
TitanRider is offline   Reply With Quote
Old 05-01-2008, 04:22 PM   #223
cobra_fanatic
My '05 XE blew its first rear right axle seal at 47K miles and now at 66K (out of warranty at 60K) the seal is shot again and I have a bad seal on my tranny...this blows.
Alright, filed a complaint:
Your Confirmation number (ODI Number) is: 10226433
cobra_fanatic is offline   Reply With Quote
Old 05-07-2008, 09:17 AM   #224
Galaxyblack
Galaxyblack's Avatar
Having seals replaced now. Both were leaking. Filed complaint.
'04 LE Big Tow
123,000 miles
$350 a side to replace at dealer
Service writer/assistant service manger comment: "you have been lucky not to have had to replace your rear end yet"
YIKES!!!
2004 LE 4X4 Crew Galaxy Black, Leer 100R shell, Chrome tailgate trim, Chrome stock wheels, chrome door sills, Zoomers cat back, 2*advance, 120,000 miles going strong.
As my dear old Dad said, "You've got to stop and smell the roses once in a while". He didn't.... I plan to know the smell of them roses intimately.
Galaxyblack is offline   Reply With Quote
Old 05-10-2008, 08:25 PM   #225
BHMTitan
I had the right side replaced under warranty, at 29K. Complaint filed.
06 SE KC, 4x4 BT OR Smoke
2* Advance
Dominator II Steps
BHMTitan is offline   Reply With Quote
User Name
Password
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 03:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 08:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 09:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 02:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 05:18 AM
Search this Thread:
Advanced Search
vB code is On
