Old 05-20-2008, 12:20 AM   #226 (permalink)
Re: Rear axle seals leaks. Please report.
How much was it to repair yours....same prob w/ mine
schay is offline   Reply With Quote
Old 06-01-2008, 08:19 PM   #227 (permalink)
I just purchases an '04 CC LE and the driver's side seal has been leaking for some time. It was caked on almost 1/4" thick in places.
I can't post pics yet, but you can see it at smithplanet DOT com/temp/axleseal.jpg
I think this is the only thing I didn't check before buying the truck. And apparently the dealer missed it in the pre-sale 'thorough' inspection. The fluid was about an inch low, but looked fine - it was probably changed shortly before the sale (again, dealer didn't notice this?!?)
Luckily, it's just within the warranty - I'm going to push for an entire new backend as this problem seems to continually rear it's ugly head after it shows up once. I'll let you know how it goes.
Filed a complaint - conf. #10229464.
2004 LE Crew Cab, Silver, 4X4, tow package, nav, DVD, and the works. PRG Leveling Kit on its way.
apollosmith is offline   Reply With Quote
Old 06-06-2008, 04:30 AM   #228 (permalink)
rsw007's Avatar
just made my dealer replace my entire rearend cause both axle seals were leaking and reaend was way low on fluid.
04 xe cc with qx56 wheels, ventshades, bed cover,2.5" level kit, air ride on rear and custom duals with quiet magnaflow
pulling 08 cherokee 28a+ camper
or 91 mustang drag car www.putfile.com/rsw007
rsw007 is offline   Reply With Quote
Old 06-12-2008, 05:21 PM   #229 (permalink)
I bought my 04 cc truck a couple years ago and I thought I recalled the guy I bought it from saying it had the extended 75000 power train warranty and I just nocitced my real seal leaking. Anyone heard of the 75000 warranty?
2004 SE, CC, Big Tow package, Westin chrome nerf bars, undercover bed cover, OEM fog lights, rain guards, Flowmaster dual exhuast, 2" leveling Kit.
jbiscoe is offline   Reply With Quote
Old 06-16-2008, 09:45 PM   #230 (permalink)
EseLoco918's Avatar
wish I read this thread earlier.
Truck is an '05 with 35k.
Rotated my tires when I got home today, have a bad axle seal leak on my passenger side. Never noticed it, stayed on the back of my wheel. Don't know how long it has been broken.
Calling the local dealer tomorrow.
filed this already:
Your Complaint Information is successfully submitted.
Your Confirmation number (ODI Number) is: 10231245
This damn truck is starting to have more problems than my ranger did. I guess my next truck is a Toyota.
On the advice of legal counsel, this section contains no message...
EseLoco918 is offline   Reply With Quote
Old 06-18-2008, 08:38 AM   #231 (permalink)
When you guys say you filed a complaint is that with NissanUSA?
krc333 is offline   Reply With Quote
Old 06-19-2008, 11:01 AM   #232 (permalink)
Rear seals replaced at 57,000 miles. Complaint submitted per this thread. Complaint number 10231597. The work was done by my mechanic because I didn't think it would be covered by the warranty.
Hampstead38 is offline   Reply With Quote
Old 06-20-2008, 08:09 AM   #233 (permalink)
Complaint Filed: ODI Number is: 10231682
I noticed oil leaking inside passenger rear wheel.
From the dealers service print out after service was completed:
Cause: F
NE15AA RPL BOTH AXLE SHAFTS/BEARINGS
857 WPN
2 43252-7S200 Seal-Oil R
2 40210-7S210 Bearing-RE
2 43070-7S200 Spacer Axl
1 43082-7S210 Cage Rear
1 999MP-AH000
eclipsyo is offline   Reply With Quote
Old 06-25-2008, 12:11 PM   #234 (permalink)
Dealer said both of mine were leaking and said that he heard some pinion whine(gear oil is probably low from the leaking) so they are replacing the whole rear with the new part. I just bought the truck and took it in for a look over and they found that. Hopefully I will have a new rear end and TrueTrac by the start of next week.
'02 Subaru WRX:--------~380whp T67 STI Engine/ STI Trans swapped *SOLD*
'95 M3------------------modded suspension *SOLD*
'04 Mustang Mach 1:----31 splined, 4.30 geared and Watts Linked/Tri Linked *SOLD*
'04 Titan Crew Cab SE:--Big Tow, RollnLock, Magnaflow 12256, 2* advance, 2.5/1 Minilift... To be installed: TrueTrac...
Next on the list... UpRev, headers/B-pipe
eightballrj is offline   Reply With Quote
Old 06-25-2008, 12:24 PM   #235 (permalink)
Kronos1965's Avatar
#10232280
Just lost my second seal at 66,000
Kronos1965 is offline   Reply With Quote
Old 06-27-2008, 01:01 PM   #236 (permalink)
cneary812's Avatar
well I check for leaks regularly and last night I found the dreaded drips on the drivers side. Looks like it has been leaking for about a week or 2. I will get the dealer to fix it next week. They told me today they would need it at the beginning of the week not the end so I guess ill have to wait till monday.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 06-27-2008, 03:00 PM   #237 (permalink)
Picked mine up today (getting TSB done) and my rear driver side was leaking and I’m taking back on Monday (didn’t have the part today) to have it fixed. They must be doing it as goodwill because the dealer told me the powertrain warranty would cover it even though I have 63k on my 04.
Old 06-27-2008, 05:36 PM   #238 (permalink)
Same thing here... 60900 on it and replaced the whole axle (due to axle seals leaking and pinion whine). I think Nissan doesn't want any bad press on these trucks to hurt the already hurting sales. But, either way... I'm HAPPY!
Old 07-01-2008, 05:40 PM   #239 (permalink)
titanville05's Avatar
I found the dreaded drip on the driver's side on Sunday. I took it to the dealer and they are replacing rear diff, seals, etc. They said the redesigned differential will allow more ventilation to keep the heat down. We'll see. Also having them check the manifolds while it is there. Anything else I should have them look at??????
2005 Titan CC SE, 34,200 miles
titanville05
titanville05 is offline   Reply With Quote
Old 07-01-2008, 05:42 PM   #240 (permalink)
I also filed a NHTSA complaint per this thread. Thanks for the link.
titanville05
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 04:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 09:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 10:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 03:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 06:18 AM
