Old 10-02-2006, 12:15 PM   #61 (permalink)
Re: Rear axle seals leaks. Please report.
The service tech just told me today that nissan has upgraded the seals. They are going to replace both seals even though only one side is leaking.
beatervan is offline   Reply With Quote
Old 10-02-2006, 01:30 PM   #62 (permalink)
That would great if it is infact true. Keep us updated and report it.
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 10-02-2006, 01:50 PM   #63 (permalink)
replacement seal part # on mine was #43252-7S200. Let us know if yours is different.
Old 10-02-2006, 06:41 PM   #64 (permalink)
herpov--is the part number you have given us from the white sticker near the diff?
white
whiteLE is offline   Reply With Quote
Old 10-03-2006, 12:53 AM   #65 (permalink)
NorCal 4x4's Avatar
Here's what my axle seal leak looked like. Since the dealer drained my Schaeffers 267 Moly 80W90 synthetic-blend, (pic shows full synthetics don't climb like the blend does ??? The stuff sure kept the diff cover cool., and put in that Nissan Corp. full synthetic stuff, I think I might be posting on the rear-end failure thread before long. Well I guess a 4-pinion spider gear would be pretty nice, so I shouldn't complain.
Old 10-03-2006, 07:07 AM   #66 (permalink)
white
No, it is the part # of the seal itself.
Old 10-03-2006, 07:11 AM   #67 (permalink)
They did not drain mine, they just topped it off when they were done. No need to remove the diff. cover that I know of.
Old 10-03-2006, 07:54 PM   #68 (permalink)
Learjet's Avatar
Unhappy Re: Rear axle seals leaks. Please report.
My neighbor's '04 KC. big tow is leaking on the driver side axle. He doesn't seem too concerned.
Learjet is offline   Reply With Quote
Old 10-03-2006, 07:56 PM   #69 (permalink)
Learjet's Avatar
Hey! that was my first post. Been hanging around for a few months and decided to join the club.
Now I need a few more, so I can post a picture!
Old 10-03-2006, 08:48 PM   #70 (permalink)
NorCal 4x4's Avatar
Did they crack off your old bearings and press on new ones on yours?
They had to send the axle, or some part of it, out to a local shop because the did not have a press big enough.
I can tell they took off the cover too, because there is some of that orange high temp RTV showing. I would have used black but no big deal. And they fill with the Nissan synth.
Old 10-03-2006, 09:37 PM   #71 (permalink)
New bearing and new seal. Did not remove diff cover.
Old 10-04-2006, 07:31 PM   #72 (permalink)
beano's Avatar
Took mine in today. Left rear leaking . Dealer said it spun a bearing and their going to replace the whole rear end with a new one. 30,000 mi. 04.
04,Galaxy Black,Titan CC,4Wh dr,Big tow, Off road
Mods:
K&N,Fac Bug Shield,Westin Chrome step bars,tonneau masters cover,mobil 1,Zaino Bros.,Flowmaster duals
beano is offline   Reply With Quote
Old 10-04-2006, 07:35 PM   #73 (permalink)
Justintoxicated's Avatar
Mine is going in next week for a new axle, I have to drive it in the meantime with the leaky seals...Seems odd they want to replace the entire rear axle, but whatever...Hopefully there is some update to it. My friend has the same exact truck and year as mine and he has gone through all the same problems as well. Well his Diff Gernaded, mine just has leaky seals.
24k 05. Will file a report tonight.
BTW, I still have the factory tires and have not done any mods to the rear end....Although I serously don't understand why chaning the tires would be such a big deal that it messes up the seals...thats BS... Tires are a replaceable part, and it is especialy common to change the size of tires on a truck..
OID = 10169973
Old 10-09-2006, 03:00 PM   #74 (permalink)
Looks like about 20 reports so far. If you have a leak or had a seal replaced, please report. Thank You.
Old 10-09-2006, 07:50 PM   #75 (permalink)
Originally Posted by MississippiTitan
Can you file these with NSTHA? (however you call it) If so we ought to keep track of these like the rear ends it seems the read ends and axle seals are a major flaw for the Titan
Yes, please do. www.nhtsa.dot.gov
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 04:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 09:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 10:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 03:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 06:18 AM
