Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Rear axle seals leaks. Please report. - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 10-09-2006, 07:21 PM   #76
MississippiTitan
MississippiTitan's Avatar
Send a message via AIM to MississippiTitan
Re: Rear axle seals leaks. Please report.
Can you file these with NSTHA? (however you call it) If so we ought to keep track of these like the rear ends it seems the read ends and axle seals are a major flaw for the Titan
2006 Blizzard White CC SE 4x4
Popular Captains, Big Tow, Off Road
MODS:
PRG Leveling Kit
35" Mickey Thompson MTZ's
DIY Airbox Mod
AMSoil Drop In Air Filter
http://community.webshots.com/user/darbo650
MississippiTitan is offline   Reply With Quote
Old 10-12-2006, 09:12 AM   #77
rrtitan
rrtitan's Avatar
When filing with NHTSA, they ask questions as if they are interested in whether the failures caused an accident, not if a part failed. I'm not sure I'm going to file it. It asks you speed of the incident, etc. I was only planning on reporting that my Diff leaked on the left rear.
rrtitan is offline   Reply With Quote
Old 10-12-2006, 11:11 AM   #78
ucf_motorcycle
ucf_motorcycle's Avatar
Anyone think Nissan will have a recall on this item soon? My truck has 77,000 miles so out of warrranty and the axle seal is leaking.
ucf_motorcycle is offline   Reply With Quote
Old 10-12-2006, 11:13 AM   #79
P's Titan
Supporting Vendor
P's Titan's Avatar
mine as a minor leak and I am getting a new rear diff assembly. Does anyone want pictures ?
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 10-12-2006, 01:45 PM   #80
Bartlett Titan
Bartlett Titan's Avatar
Hey, I noticed they have a TSB on it. Something about a breather? Does the TSB mean anything to us? I have take mine in 2 times. No mods to the back in of my truck. The last time I took it to another dealer and they were trying to tell me I had to take it back to the one that did the original work. After I pretty much told them no they looked at it and said there was no leak despite the diff. being wet looking around the bolts. The said they understood what I was talking about though. They didn't fix my leaking rear windows either!
Galaxy Black cherry of a truck with Carriage Works Billet Grill, Auto Vent Shade Deflector, DOS Nerfs, 20% Window Tint, XM, Hooker Turbo Swept Side Exhaust, NCD leveling kit
Bartlett Titan is offline   Reply With Quote
Old 10-12-2006, 01:49 PM   #81
Wiscdave
Wiscdave's Avatar
Please post the TSB on it, I'm very interested to see if they are doing something now.
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
Old 10-12-2006, 02:27 PM   #82
Herbpov
That TSB has to do with removing the breather from the old axle and installing it on the replacement unit.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 10-12-2006, 02:29 PM   #83
Herbpov
Are you getting a new rear diff assembly just because of the leak or do you a diff failure??
Old 10-12-2006, 03:16 PM   #84
MississippiTitan
these seals cant be that much right?
Old 10-12-2006, 06:09 PM   #85
titanmike
titanmike's Avatar
the seal i had replaced would have been around 350 if i didn't have a warranty.
04 SE KC. BT OR 110,000 miles and going strong.
06 LE KC. BT 31,000miles. S&B Intake. 22" magnaflow muffler. 2* timing advance. rear fog lights. 2.5" leveling kit. Air Lift airbags. Back up camera. 18x8.5 Viscera 506's w/ 325-60-18 Nitto Terra Grappler A/T's. Bushwacker fender flares color matched. 6000 hid low beams and fog lights.
titanmike is offline   Reply With Quote
Old 10-16-2006, 11:45 AM   #86
FlimFlamMan
FlimFlamMan's Avatar
Bummer.... just noticed my rear left leaking yesterday. Its not a massive leak but enough to warrant attention. Damn the luck.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 10-16-2006, 12:48 PM   #87
crownsey54
mine on my passanger side is gone i looked under there today and it is all over the rim and the disk brake. funny thing is i just got it a month ago.
crownsey54 is offline   Reply With Quote
Old 10-16-2006, 03:01 PM   #88
Herbpov
Report it as a safety problem. Possible brake failure.
Old 10-16-2006, 03:16 PM   #89
MississippiTitan
it sounds like these are going bad just like the rear diff. I wonder what is the culprit?
Old 10-16-2006, 10:51 PM   #90
kartman
kartman's Avatar
My personal theory is heat with crappy breather system.
Rebar Wrangler
User Name
Password
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 03:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 08:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 09:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 02:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 05:18 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
  • Manuf
