Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Rear axle seals leaks. Please report. - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 10-23-2006, 06:42 AM   #91
trkconvert
trkconvert's Avatar
Re: Rear axle seals leaks. Please report.
I had my Truetrac installed a couple of weeks ago and I had not noticed any leaks before the install. So I got under the truck yesterday to change the rear diff oil and saw leaks on both sides covering the rear brake assemblies. Now I understand that I have the seals leaks BUT could the installation be the cause or it is simply a coincidence and this would have happened anyway?
Black de-badged 2006 Nissan Titan CC LE 4WD. Mag-Hytec diff cover, TrueTrac, T-Rex Billet Vertical Grille and Bumper Insert, Sway-a-way coilovers, Total Chaos control arms, Donahoe Racing rear shocks
trkconvert is offline   Reply With Quote
Old 10-23-2006, 12:56 PM   #92
FlimFlamMan
FlimFlamMan's Avatar
It is possible that the shop that installed the TT did not clean the area up after installation (that was in my case). To be sure, I would wipe the area clean and check it frequently. If it starts showing up again then it should be fixed.
The manual says that the seals should always be replaced when the axle is pulled. However, this is a known problem with Titans. When I take mine in I am not going to say a word about the TT. I'm going to say the diff is fine... fix the seal. Warranty work, imo.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 10-26-2006, 12:40 AM   #93
Justintoxicated
Justintoxicated's Avatar
I also noticed oil around my vent. Is this normal? I'm thinking to do the rear axle breather vent mod, but I want to make sure I get the attachment that threads in properly...
Finaly going in next tuesday for the axle replacement
Old 10-26-2006, 03:27 AM   #94
trkconvert
trkconvert's Avatar
I have rechecked the leaks and it seems these are indeed the stains left after the installation. I will now have to check frequently to make sure these are not the leaks. Anyway I am now thinking of doing the breather vent mod but I am concerned that for some on this forum it did not work or worked the opposite way.
Old 10-27-2006, 07:51 PM   #95
Toxman
Toxman's Avatar
Send a message via ICQ to Toxman
I ran the factory diff fluid that the service department put in after my seal repalcement for a couple of months. I checked it today and it looked terrible! It was pitch black and had a terribly stench!!!! I Replaced it with Mobil 1 which I had been running prior to the seal replacement. What kind of crappy diff fluid is Nissan using?
2004 Titan CC LE - Born 10/04
Mods:
  1. Westin Bull Bar
  2. Flowmaster Exhaust
  3. 2" leveling Kit
  4. K&N drop in filter with stock air box mod
  5. BF Goodrich 315/70/R17 T/A AT KO tires
  6. Active Tuning grounding kit
  7. Under seat storage bin
  8. Silver Star Halogen Headlights
  9. Nissan Sliding tool box
Toxman is offline   Reply With Quote
Old 10-28-2006, 12:59 AM   #96
trkconvert
trkconvert's Avatar
I also had to have the front diff fluid changed when installing the Truetrac since it was black and it was actually underfilled.
Old 10-29-2006, 06:52 PM   #97
whiteLE
Attached is the latest rear end failure log. Feel free to reply if you have had a seal failure.
thanks
white
whiteLE is offline   Reply With Quote
Old 11-06-2006, 05:25 PM   #98
Justintoxicated
Well they finaly fixed mine, but didn't give me the new axle they ordered....They just pressed in a new seal and said they are no longer replacing entire axles for this problem. The guy there said there has been some problems of the seals not being pressed in properly.
Old 11-06-2006, 07:15 PM   #99
Aquaholic
Aquaholic's Avatar
Filed my complaint right now. My rear passanger axle seal was replaced today. It was in the shop 2 times in the last week and the dealer didn't catch it so I took it somewhere else.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 11-14-2006, 07:09 PM   #100
DStewart
DStewart's Avatar
I brought my truck in today for a trans cooler leak and they found the Rt rear axle seal leaking "at a steady drip" they said. I have 32k.
SOLD:2004 Nissan Titan 4x4-Smoke, Big tow, SE bed package, Popular package w/ captains chairs.Mods: updated aluminum rear diff cover, K&N drop-in filter, PRG lift, Firestone air bag kit, 17x9 Eagle Alloy 101's, 295/70R17 Nitto Terra Grappler, polished Billet grille-upper 3 piece and lower.
2005-FS2600 Weekend Warrior toy hauler
05 Honda CBR 600RR Black/Gunmetal w/Tribal Flames
DStewart is offline   Reply With Quote
Old 11-14-2006, 07:14 PM   #101
whiteLE
thanks for the info. The link is below if you want to file a complaint with the NHSTA.
White
Old 11-14-2006, 07:22 PM   #102
whiteLE
Attached is the latest log with Dstewart's and Harden's additions. We are at 61 failures with 4 being axle seal leaks.
thanks
white
Old 11-14-2006, 07:29 PM   #103
DStewart
DStewart's Avatar
Don't know if it matters, but I have VDC and max towed is 9k.
Old 11-21-2006, 05:51 PM   #104
fiveboyces
My Titan has 30750 miles and the seals leaking like crazy. Its going in tomorow. Hope it turns out alright.
fiveboyces is offline   Reply With Quote
Old 11-21-2006, 07:24 PM   #105
whiteLE
five--let us know how it goes. Please give us the background information your Titan. Also, if you want to file a complaint, the link is below.
All
It is my understanding the axles are leaking rear diff fluid. If so, it make sense to keep driving the Titan until enough leaks out to ruin the diff, especially if short trips are in the future.
comments?
white
User Name
Password
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 03:41 PM
rear slider leaks/not tsb prob squatch Titan Problems & Dealer Service 1 01-27-2006 08:17 AM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 09:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 02:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 05:18 AM
Search this Thread:
Advanced Search
vB code is On
