Old 08-15-2006, 09:08 PM   #1 (permalink)
Brundy's Avatar
full floater
Since Titans use a Dana 44 rearend, has anybody tried bolting on a spindle from a front Dana 44? We used to convert Jeeps this way all the time because they would bolt right on. By going full float, we can use stonger axles,carry more weight, and maybe eliminate axle seal problems.
I haven't found a spline count for our axles. Does anybody know?
What carrier do the 4x4s have up front? Spline count?
Lastly, I know TruTrac is a good diff. In my last rearend I tried a Loc-Rite, 3 times, before going with an Eaton (GM 10.5 14 bolt). I loved the LR offorad, but it was a pita on the street. Is anybody running anything besides the oem locker or TruTrac? What are the characteristics?
Thanks, BRUNDY
Brundy is offline   Reply With Quote
Old 08-16-2006, 05:59 AM   #2 (permalink)
Sammy Sandbag's Avatar
Re: full floater
Here's a good thread on the TruTrac: Truetrac in Titan - Review
Our axles are 32 spline.
More good info on the rear end: Differential Info
-Counsel Yourself
Old 08-18-2006, 06:37 AM   #3 (permalink)
loufish's Avatar
Re: full floater
Just to clarify, we have a Dana rear end based on the "Super 44" used in some Corvettes and Vipers. It's not a "Super 44" either, just a variation of one. Actually the Titan has pretty good size axles, the ring gear is a little small in diameter(about 8.5") but the weak link seems to be the spyder gears...
By the way a great idea, converting to full floater.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 08-18-2006, 07:14 AM   #4 (permalink)
Brundy's Avatar
Re: full floater
Just my luck. One reason I bought this was for the rear end. Nissan used Dana 30s in front on their minis. What are they using now in the front of Frontiers & Titans?
Thanks for the info...
Old 08-18-2006, 07:35 AM   #5 (permalink)
Re: full floater
According to The Head's measurements, it is 9", not too shabby. Agree on the spider gear issue though.
-Counsel Yourself
Full Brush Guard Mountainmac Buy/Sell 19 11-01-2006 11:56 PM
Floater Rim Titan DeTitan Titan General Discussion 17 12-02-2005 10:06 AM
K&N full system?? GaryB Titan Performance Modifications 0 08-08-2005 06:53 PM
Niteblitz your PM is full QShip Titan General Discussion 0 03-21-2005 08:59 AM
Not quite full? joeandmaria Titan General Discussion 10 05-17-2004 03:30 PM
