I too had to use channel locks to get the filter off. I always tighten filters hand tight so i can use my hand the next time. But the next time i had to use channel locks again. Something about this filter, it tightens up on its own. The main problem is there is not enough room to really get a grip on it.
What the real problem here is the filter location. I've fabbed a bracket to remote mount the filter. The bracket mounts to the pass. side engine mount (drill 2 holes) so that it can drain into the same pan as the engine.
I'm thinking of making a bunch and offering them on here.
Always hand tighten the filters...otherwise you'll have a big mess, and possibly a lunched engine if you use a wrench.
Most cartridge filters will draw tight on their own
I had to use a big pipe wrench to get mine off the first time. Channel locks weren't doing it for me. It was a little tough fitting it into position, but I only need a small amount of swing room to break it free. They definitely overtighten these at the factory.
I do love the little oil drain chute. It works well, but is hardly innovative. My wife's 2000 Expedition has one, albeit plastic.
My Fast is not concerned with gas mileage...
2006 Crew Cab LE 4x4
(2005 Lemon is gone...)
Smokin Hot Smoke Color
Step Bars
Big Tow
Sirius Satellite Radio
Creative Zen MicroPhoto Player (Screw iPod)
Undercover Tonneau
Nissan All Weather Matts
Once again..I repeat...never tighten the filters with a wrench...the engine will then draw the filters up, splitting the case. If this happens in your garage, you'll have a big mess, on the road, you'll have a big expense.
At 60 MPH, you'd be amazed on how fast 7 quarts can be pumped out of a split filter.
Whatever method used at Nissan to install filters on new engines is unknown to me, but I can't believe a wrench is involved.
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/Amsoil EAa104 filter
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
Dude,
I needed the pipe wrench to remove it.
To install, I use a breaker bar.
Step Bars
Big Tow
Undercover Tonneau
I'm thinking I'll be lazy and let the dealer change my oil on the new titan for a while. But I must ask:
1. Did I read it wrong above, is their some sheild I have to remove to get to the filter??
2. I also saw somewhere that you have to put a new crush washer on the drain bolt every oil change???
