Old 08-17-2006, 09:17 PM   #1 (permalink)
hondarider227's Avatar
Gear Ratio
Have a 05 4x4 tow package what gears are in this truck. I tried to search can't find any thing thanks for the help.
JBA HEADERS
FULL CUSTOM EXAUST
SPINTECH MUFFLER
VOLANT INTAKE
6IN PROCOMP LIFT
Fox Shocks
PROCOMP TRACTION BARS
ECLIPSE NAV SYSTEM W/BACKUP CAM, AND IPOD HOOK UP
KICKER 10
INFINTYS IN ALL DOORS.
Sirius sat. Would never be without it again.
hondarider227 is offline   Reply With Quote
Old 08-18-2006, 01:25 AM   #2 (permalink)
SOCALTITANKC4X4LE's Avatar
Re: Gear Ratio
Non Big Tow: 2.94
Big Tow: 3.36
Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 11-21-2006, 04:30 PM   #3 (permalink)
Re: Gear Ratio
Look on the passenger door sticker. there is a "C" number on the bottom of the sticker. If it says C29 that would be a 2.94 ratio. C33 would be 3.36 ratio etc.
westex39 is offline   Reply With Quote
Old 11-22-2006, 03:30 PM   #4 (permalink)
Re: Gear Ratio
Excellent tip that I have never known about. Thanks!
XRING600 is offline   Reply With Quote
Old 11-27-2006, 05:35 PM   #5 (permalink)
Learjet's Avatar
Re: Gear Ratio
well...my door sticker has "C29" and I have the big tow? The sticker on the axle is correct.
So, my sticker on the door is wrong are this is not correct info?
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 11-27-2006, 05:45 PM   #6 (permalink)
CVTITAN's Avatar
Re: Gear Ratio
UH-OH.. Some clearification please..
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 11-28-2006, 03:12 PM   #7 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
Re: Gear Ratio
do you have the tranny temp gauge? If I'm not mistaken, that's another giveaway if you have the BT or not
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 11-28-2006, 03:42 PM   #8 (permalink)
TitanBlue's Avatar
Re: Gear Ratio
OR also has the BT gearing, correct? Does it have the temp gage too?
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 11-28-2006, 04:45 PM   #9 (permalink)
Taleen The Titan's Avatar
Re: Gear Ratio
no i have the OR but not the BT and i think it is the same gearing, but it doesnt have the temp gauge. im thinking about buying an aftermarket oil cooler, does anyone know if i can install a BT temp gauge where it should be?
http://s91.photobucket.com/albums/k2...t=P1010011.jpg
///SIG IMAGE TOO LARGE\\\
Volant CAI
Black Grill
Banks Monster Exhaust
Alpine CDA-9847
Alpine KCE-422i Ipod Adapter
Diamond Audio D6 1000.1 Mono Amp
Dual Diamond D3 10" Subwoofers In Customs Box Under Rear Seats
Fabtech 6" Basic Lift Kit
Akuza 349 18" Chrome Wheels
35" Hankook Dynapro RT03 MT Tires
Taleen The Titan is offline   Reply With Quote
Old 11-29-2006, 07:17 PM   #10 (permalink)
TitanBlue's Avatar
Re: Gear Ratio
Search for oil cooler, as there is some sort of oil cooling function std on the titan. No, I'm not talking about the Trans coolers, there is oil cooling already on it, not very big though.
Born June 12, 2006
Old 12-10-2006, 07:24 AM   #11 (permalink)
stormsracing10's Avatar
Re: Gear Ratio
i have a trans temp guage and not the big tow package. and my sticker is on the driver side door. it says c29
stormsracing10 is offline   Reply With Quote
Old 12-12-2006, 08:19 PM   #12 (permalink)
silverbeast's Avatar
Re: Gear Ratio
just checked my door and it has cc29! and i have big tow, 4x4. so i crawled under the truck to check the rear axle sticker. it has 3.357 gear ratio. was gonna be pissed if it had 2.94 ratio. but could the sticker on the rear axle be wrong?
**06 TITAN CC SE 4X4 BIGTOW**
**FLOW MASTER**
silverbeast is offline   Reply With Quote
Old 12-13-2006, 03:55 PM   #13 (permalink)
Re: Gear Ratio
were did you see the axle sticker? crawled under mine last night to check my ratio and there is no sticker
Old 12-13-2006, 10:13 PM   #14 (permalink)
Yahooligan's Avatar
Re: Gear Ratio
I, too, have an axle code of "CC29" and I have BT. It would appear the assumption of "29" relating to the axle ratio would be incorrect.
2005 Titan SE CC 4x4
2008 Dodge Grand Caravan SXT - Wifemobile
1993 Jeep YJ, heavily modded rock monster - FOR SALE - Buying a boat
Yahooligan is offline   Reply With Quote
Old 12-14-2006, 02:40 PM   #15 (permalink)
Re: Gear Ratio
the sticker is on the botton of the diff. right behind where the rear drive shaft connects to the rear diff. i had to wipe off my sticker because it was black from road grim.
**FLOW MASTER**
gear ratio RO.CO3 Titan Engine, Transmission & Drivetrain 5 01-01-2006 07:47 PM
gear ratio RANDY Titan Engine, Transmission & Drivetrain 17 11-23-2005 09:27 PM
Gear Ratio RANDY Titan Engine, Transmission & Drivetrain 11 08-27-2005 02:09 AM
gear ratio bennieblunt Titan Engine, Transmission & Drivetrain 8 06-11-2005 01:12 PM
gear ratio Skeeter Titan General Discussion 8 02-24-2005 12:48 PM
