Re: Question regarding Walmart (Supertech) synthetic
GoogleWhore to the rescue:
WalMart is known to use at least two suppliers for their "SuperTech" brand motor oil: ExxonMobil back east and parts of the midwest, and Warren Performance Products in most other areas. There is evidence that in some cases SOPUS has supplied motor oil under the SuperTech name, too, based on the use of jugs that are physically identical to those used for certain Quaker State and Pennzoil product and an identical alpha-numeric product/date code format stamped in the jugs' bottoms. So far as anyone has been able to tell from UOAs, SuperTech motor oils are good performers, though I can't say they particularly stand out in any category. As for SuperTech oil filters, that question would be more properly addressed to BITOG's oil filter discussion forum. I can tell you that they're made for WalMart by Champion Labs and contain a synthetic blend media. I've used them consistently in the past and never had any problems with them.
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore™
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
