Old 08-29-2006, 05:58 PM   #1 (permalink)
ucf_motorcycle's Avatar
Clunk right after startup
My titan makes a clunk sound about 1-2 seconds after a cold startup. It sounds similar to shifting a motorcycle out of neutral.
No other noises are heard when shifting or any thing.
The truck makes this noise while it is sitting in park. (no shifting)
Any ideas what this is and is it normal or should I be concerned?
ucf_motorcycle is offline   Reply With Quote
Old 08-29-2006, 06:02 PM   #2 (permalink)
Blackbeauty's Avatar
Re: Clunk right after startup
Can you isolate the clunk? Is it from under the hood? Dash? Rear seats? Under your feet? Mine is clunky when I'm parked on a slight incline and shift from park to R or D, but not while standing still. Personally, I would be concerned. Does it do it EVERY time? In other words, if you took it to a dealer, would it duplicate itself for them?
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Blackbeauty is online now   Reply With Quote
Old 08-29-2006, 06:06 PM   #3 (permalink)
BKW
Three Titans...three clunks...back out of sloping driveway, head down the hill....after 30 feet or so...CLUNK...at right front end.
The 04 SE KC did it, the 05 LE CC did it, and the 06 SE CC is doing it..
I looked..asphalt isn't torn up, no manhole cover....and the Murano doesn't do it...must be a ghosn in the machine.
BKW is offline   Reply With Quote
Old 08-29-2006, 06:08 PM   #4 (permalink)
BKW, yours sounds like a bushing, or on the outside chance a balljoint (not likely). But standing still? I don't know about that one.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 08-29-2006, 06:10 PM   #5 (permalink)
BKW
Noise has occured on 3 different Titans...must be the slope of the street, otherwise I haven't a klew....
Old 08-29-2006, 06:13 PM   #6 (permalink)
Yellomantis's Avatar
Is your A/C or defroster on when you start the truck? It could be the condenser engaging.
www.myspace.com/yellomantis
Old 08-29-2006, 06:13 PM   #7 (permalink)
Could be the weight of the vehicle on the angled road causes the "unsettlement". I get it sometimes on my left front corner, but it's not consistent. It only does it certain places. I would bet it's a bushing. New poly bushings to replace the rubber ones might do the trick.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 08-29-2006, 06:14 PM   #8 (permalink)
BKW
BTW...whenever you park on a slope, apply parking brake FIRST before putting gearshift in park, otherwise that clunk you hear may be your parking pawl going south.
Old 08-29-2006, 06:17 PM   #9 (permalink)
I do that all the time. Still does it. Not as badly, but still does it. I need to adjust my parking brake now as I've noticed it goes further down without the tight engagement it used to have. [<<<Things about Titans that sound dirty, but aren't]
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 08-29-2006, 06:17 PM   #10 (permalink)
BKW
Can't be a bushing (unless all three trucks have defective ones)...all three trucks were/are low mileage, and overpampered...it's gotta be the street. Current Titan bought 12/29/05, just turned 2400 miles.
Old 08-29-2006, 06:22 PM   #11 (permalink)
A/C is always on so it may be the condenser engaging like Yellomantis stated. I'll try starting it tommorow with the A/C off.
If it is infact the AC is the clunk normal? It sounds harsh.
Old 08-29-2006, 06:23 PM   #12 (permalink)
it is normal, you just have good ears. Mine does it all the time.
Old 08-29-2006, 06:33 PM   #13 (permalink)
The sound is def not from the interior. It is under the hood or in the drivetrain somewhere. I really only notice it if I turn the truck over before i shut the door. It sounds like the truck is being shifted but its not and it doesn't lurch or anything.
I guess no one else has noticed this problem. HMM. I will probably try to isolate it then.
Old 08-29-2006, 06:35 PM   #14 (permalink)
Is the truck warm or cold when this happens? If the truck is warm it might also be the fan clutch engaging.
Old 08-29-2006, 06:51 PM   #15 (permalink)
He said it only does it on a cold start up. I'm going to have to listen for this.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
engine smokes @ startup plove6 Titan Problems & Dealer Service 6 01-01-2006 11:13 AM
Bang/Swoosh at startup pi3yeargrad Titan General Discussion 3 10-26-2005 03:34 PM
HELP Rear Diff? Axle? It went BANG..CLUNK...CLUNK.... standingtall Titan Engine, Transmission & Drivetrain 20 09-12-2005 08:09 AM
