Old 08-30-2006, 05:18 PM   #1 (permalink)
MississippiTitan's Avatar
Send a message via AIM to MississippiTitan
Knock On Cold Startup
My 06 knocks when I crank it in the morning or whenver the motor is not warmed also does it worse while in gear. but once it warms up it goes away. My old Chevy did that and was famous for now my titan does it. Any suggestions or things I can check. It has plenty of oil by the way.
MississippiTitan is offline   Reply With Quote
Old 08-30-2006, 05:20 PM   #2 (permalink)
Big Azz Rice Burner's Avatar
Re: Knock On Cold Startup
What type of oil and filter? I had a similar issue with mine. I found out my oil filter was bad. I was using a K&N oil filter. I switched to pure one and ams oil no noises or valve train noise.
2004 Nissan Titan SE
traded for 2006 Nissan Armada LE
True Flow/Airaid intake
20% Tint
2* Timing Advance
2006 Nissan Altima SE-R
AEM intake
15% Tint
Big Azz Rice Burner is offline   Reply With Quote
Old 08-30-2006, 06:32 PM   #3 (permalink)
im on my 3rd oil change I get it changed at Nissan so whatever they use.Truck has 7,800 miles on it.
Old 08-30-2006, 06:43 PM   #4 (permalink)
I have had this for a while too. Sometimes it sounds like a diesel for a bit but it always goes away. I use a pure one filter and mobil 1 10/30.
Had a lady knock on my window... Jollysammy Titan General Discussion 4 06-26-2005 09:14 PM
Does the Titan use a knock sensor? carteach0 Titan General Discussion 3 03-27-2005 07:39 PM
Whats that knock in my front end. Arthur cole Titan Performance Modifications 4 02-15-2005 09:49 PM
cold knock problems... maestro Titan General Discussion 6 01-03-2005 02:11 AM
Knock /clunk.... Right Front import2nr Titan Problems & Dealer Service 0 12-04-2004 01:36 PM
