Old 09-05-2006, 04:29 PM   #1 (permalink)
Rearend oil and additives
I know this has been talked about 100 times, but I am wondering if anybody has heard of this mixture of oil. I am a firm believer of BG products. I am using there 75/140 ultra guard oil. A BG rep told me to add there limited slip fluid even if I donot have a limited slip rearend. He said it helps the oil from shearing at high temps. He said the hotter the oil gets the limited slip additive keeps it more stable. I did add some to my rearend to see what happens. I also use there MOA oil additive and super cool additive to my cooling system. I tow a tt and like to keep things cool as I can. Just wondering if anybody also uses there products.
Ramon is offline   Reply With Quote
Old 09-05-2006, 04:38 PM   #2 (permalink)
ArmyAviation's Avatar
Re: Rearend oil and additives
Is the BG oil synthetic?. the Titan requires synthetic oil in the rears and front axle, 75w-140. If you want the good stuff get amsiol. BG products are great stuff, I use it in the full system BK44 real good cleaner. Use it evey 20k
2008 SE CC 4X4 RED BRAWN w/popular package, Big tow, Bed utility w/bed extender, Fog lights and back up sensors, Homelink
MODS:
Sirius
TomTom GPS
DIY Intake Mod w/K&N drop in
Activetune Grounding Kit Red wires
Magnaflow Cat-Back
Silverstars
Luminics Pure Blue 6000k fog lights bulbs
Nissan Steprails
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Armada Airdam mod
I did all this without wife knowing
ArmyAviation is offline   Reply With Quote
Old 09-05-2006, 04:59 PM   #3 (permalink)
Yes, the oil is synthetic.
Old 09-05-2006, 05:01 PM   #4 (permalink)
Ok then just asking. I never used any of BG oil. I guess its fine as long as its synthetic.
MODS:
Sirius
TomTom GPS
Magnaflow Cat-Back
Silverstars
Nissan Steprails
2* Timing
Nissan Bug Shield
Armada Airdam mod
Old 01-14-2007, 03:57 PM   #5 (permalink)
Apparently the 04' F150's have had many rear end problems also. A friend of mine mentioned the Ford dealer put in some kind of "super lube" into his rear end after he started having problems. The rear end is now cured.
Anybody else heard of this?
white
whiteLE is offline   Reply With Quote
Old 01-15-2007, 04:54 AM   #6 (permalink)
A 75/140 synthetic gear lube won't shear at the temperatures seen in a normal rear differential. A limited slip lube could cause long term problems with the front face of the gear teeth, causing them to be polished away.
The "super Lube" is likely a chlorinated parrafin additive that improves the lubricity of the oil. The chlorine reacts with the metal surface and attaches itself to the metal surface, leaving the parrafin molecule to "dangle" and take up space between the metal surfaces. These molecules do help, but the olefin hanging off of the chlorine loves water, and will break down quickly.
Using a quality GL-5 synthetic 75/140 is the best bet. The aluminum cover is likely good for a 20 degree lower operating temperature. If you are having problems, the miracle additives might give you some extra time, but you will have a failure at some point.
I have 50,000 miles on my 2004 SE since 2/14/2004, one of the first ones made. I added the PML cover when it first came out and have had no problems, with very little metal in the rear diff oil when it was tested last.
KYDeepwater is offline   Reply With Quote
Looks like I'm getting a new rearend for my 04 FLfinfan Titan General Discussion 16 06-06-2006 06:00 PM
rearend failures Truck41 Titan Engine, Transmission & Drivetrain 18 12-06-2005 09:00 AM
Fuel Additives ? mod507 Titan Performance Modifications 8 05-05-2005 10:57 AM
New oil research finds zinc-based additives bad for aluminum! GO_VOLS! Titan General Discussion 2 03-18-2005 01:05 PM
Fuel Additives ? PA_Titan Titan General Discussion 5 08-02-2004 08:13 PM
