Old 09-14-2006, 11:03 AM   #31 (permalink)
ptgarcia's Avatar
Re: New Gears For Titan??
I think they should consider 3.73's and 4.10's and drop the 4.88's. The 3.73's will sell lot hot-cakes for the many trucks running the 6" lift and 35" tire that rarely, if ever, leave the pavement. The 4.10's would be better suited for the serious off-roader, whether racing or semi-rock crawling. On the street 4.10's are going to turn some pretty high rpm. 4.88's will be too low for anything but a dedicated off-road rig.
I know I don't have my Titan anymore, but if I did I'd want a set of 3.73's.
Pauly
Old 09-14-2006, 11:08 AM   #32 (permalink)
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
you went to the dark side!!
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
Toomnymods is offline   Reply With Quote
Old 09-14-2006, 07:41 PM   #33 (permalink)
bwalkertitan's Avatar
I'd defninitely be interested in a set.
2004 Smokin Nissan Titan SE CC 4x4
-Big Tow
-Offroad
-Banks
-K&N Drop-In
http://www.calidrifting.com
bwalkertitan is offline   Reply With Quote
Old 09-14-2006, 08:34 PM   #34 (permalink)
jason27's Avatar
Depending on the price some 3.73's sound good to bring my ratio back to stock after putting the 35's on
jason27 is offline   Reply With Quote
Old 09-15-2006, 09:27 AM   #35 (permalink)
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
Alright, I gotta ask the question.
I don't fully understand the gear set change and what's best?
I have the OR, BT packages and lifted with, not exactly 35's but 34 3/4 (BFG 315). I do go off road and I'm now towing a 7500 lb travel trailer occasionally. What is the ratio I would be looking at? I don't understand between the stock 3.36 BT to the 4:10, 4:88, 3:53 to the 3.73....? These are just numbers to me and I'm not clear on lower or higher is the better choice but want to learn. On the RV site you see Dodge and Chevy's with gear sets at 3.42 or 3.73 to 4.10. Is it better to go lower or higher with the ratio and how do you figure by how much?
I bet there are a couple members here on this forum that don't understand these new gears but would like to learn so I'll ask and take the heat for a newbie question...LOL
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
Old 09-15-2006, 10:09 AM   #36 (permalink)
QWIKWHIP's Avatar
DJ
I'll try and give a basic explanation, but I'm sure someone can explain it better. Because the Titan has a unique 5 speed tranny, the ratio's work out a little differently than most domestics. The 3.36 big tow/off road gears you have would be equal to a 4.10 in a domestic. When you add bigger tires, the end ratio changes, it gives you a lower number, but is actually a higher ratio. The higher the number, the lower the ratio. So if you have a 3.36 with 35" tires, you would need approximatly a 3.53 to get you truck back to the stock performance. Hopefully someone will explain it better for ya.
Old 09-15-2006, 10:11 AM   #37 (permalink)
ptgarcia's Avatar
DJ
The higher the gear ratio numerically, the lower the gearing physically. So 3.73's are a lower gear than a 3.36.
What the ratio means is it take 3.73 turn of the driveshaft to turn the axles (wheels) one revolution. So lower gears (higher numerically) will require the engine to run at higher rpm to maintain the same speed as a higher gear (numerically lower).
Why change gears? Well, when you mount a set of taller tires you effectively raise your gear ratio. This means the engine runs a lower rpm to maintain the same speed, pulling the engine out of its sweet spot where its designed to run. Swapping gears to a lower set kind of cancels the effects of the taller tires, making the truck feel close to stock again.
When it comes to gear changes I also go to a set a tad lower than that required to bring you back to stock to help make up for the added weight and rolling resistance of the larger tire.
Hope this helps.
Pauly
Old 09-15-2006, 10:37 AM   #38 (permalink)
TitanicDJ's Avatar
Hope this helps.
Thanks QWIKWHIP and ptgarcia,
This does help a lot. I never reply to these types of post on the RV site because it seems a lot of them would suggest trade the Titan for a 3/4 ton. So when you say go to a lower ratio to return to stock what set would that be the 4.88 Greg mentioned? Since we have 3.36 (BT) which is like a 4.10 in domestics is this too high or is the 4.10 with the larger tires going to get closer to stock?
Again sorry for the questions, this is helping me better understand what to look for when the gears are ready.
Old 09-15-2006, 10:40 AM   #39 (permalink)
DaFridge's Avatar
Originally Posted by QWIKWHIP
lol, For some reason I knew you would want the 4.88's.
heck yeah! for 4.88's, i'll ride my mtn bike to work if i have to.
we're not here to start no trouble, we're just here to do the SuperBowl Shuffle!!"-1985 SBXX CHICAGO BEARS!!!!
2004 DEEPWATER
AEM BRUTE FORCE DRYFLOW
CUSTOM FLOWMASTER 40 DUAL THUNDER
T-MAXX OUTBACK WINCH
procomp stage2
PRG traction bars and endlinks
American racing mojave teflon 17s
35" XTERRAINS....these tires ROCK
safari softopper
Kc LIGHTS
www.off-road.com/nissan
DaFridge is offline   Reply With Quote
Old 09-15-2006, 10:43 AM   #40 (permalink)
QWIKWHIP's Avatar
New tire size/stock tire size X stock ratio = new ratio
But like PT said, it's not a bad idea to go with a little lower ratio (higher numeric) to help with the extra weight.
That being said, I would say the ideal ratio for a lifted Titan w/35's that wants to return to stock performance would be the 3.73 gears.
Old 09-15-2006, 10:50 AM   #41 (permalink)
ptgarcia's Avatar
Stock gears are 3.36:1 and stock tire size is roughly 33". If you went to a 35" tire, you effectively lowered your gear ratio by (1-33"/35") x 100%=5.7%. To return to stock you need to lower the ratio by the same percentage: 3.36 x 1.057=3.55. So a 3.55:1 ratio gets you to stock. I like to go a bit lower, that's why I recommend 3.73's.
4.88's are way to low for a street rig.
Pauly
Old 09-15-2006, 11:04 AM   #42 (permalink)
TitanicDJ's Avatar
Thanks again, now I understand better why a lot are mentioning the 3.73 gears....Hey Greg....3.73???
Old 09-15-2006, 11:45 AM   #43 (permalink)
red_rider_elsinore's Avatar
I'd want a set too. I think the truck is undergeared (3.357) for the stock 33". Our trucks are geared to do 200+mph at redline in 5th. With 4.88 our trucks would cruise around at 2800mph at 70mph. At 70mph most of our engine's work is going into fighting to the wind. I doubt it if I see a minor if any drop in mpg. That's just my opinion though
2006 CC 4x4 Radiant Silver: Offroad Package, Tow Package
Current Mods: Glasspack muffler, Helix TB, True Flow Air Filter, Air Box Mod, Airlift Air Bags, 35x12.50x17 Big O XT LT tires, 2º Advance, 2.5" Racerunner Coilovers, Deaver MiniPack, Rear Bilstein Shocks
Wish List:Upgrade Stock Radio
2005 trx400ex: tcs Front Shocks
2001 xr650r: Tag Handlebars w/Bark Busters, Uncorked, Glass Lens Headlight, Precision Concepts Revalve, smartperformanceinc 215/VM2-K5 fork oil.
2000 yz426f: stock
1st ANNUAL GLAMIS TITAN DUNE MEET
red_rider_elsinore is offline   Reply With Quote
Old 09-16-2006, 08:04 AM   #44 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
This is exactly the kind of feedback that is needed. I aggree about the 3.73 and 4.10 bing the ratios to start with. My 4.10 with 37's is jsut about perfect, so 3.73 on 35's would be great. And the gears really, really wake-up the acceleration. I will post more as this develops.
Old 09-16-2006, 08:17 AM   #45 (permalink)
Aquaholic's Avatar
I would want 3.73
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
