Old 09-16-2006, 09:42 AM   #46 (permalink)
Re: New Gears For Titan??
3.73 for me...already have the truetrac in the rear...3.73's and a truetrac up front would give me the confidence to pin the throttle while 4 wheeling and not worry as much about grenading my front dif......
04 CC SE 4x4
CST 7" Lift
Bilstein 12" 5150 Crossflow Reservoir shocks
Magnaflow All Stainless Cat-Back exhaust
2 Degree Timing Advance
17x9 Gear Alloy 711MB modified rims
BFG All Terrain T/A KO 315/70/17 tires
Alumistinger 10" drop Super Alloy Drop bar/Ball mount
TrueTrac LSD
DMZ tube rear bumper
PRG Traction bars
PRG UCA's
SAW Coilovers
Shadowofnight2001r is offline   Reply With Quote
Old 09-16-2006, 01:34 PM   #47 (permalink)
kartman's Avatar
You know the stock ring gear will take more abuse than a 3.73. More meat on the teeth.
Rebar Wrangler
Old 09-16-2006, 01:39 PM   #48 (permalink)
Sammy Sandbag's Avatar
And a LSD up front? No thanks, IIRC the Titan doesn't have a center axle disconnect on the front end like many older trucks.
-Counsel Yourself
Old 09-16-2006, 02:00 PM   #49 (permalink)
pi3yeargrad's Avatar
Guys what do they mean then that our gears in the big tow are equivalent to 4:10's?? What do we with BT really have? and what of a difference will there be going to ACTUAL 4:10's? We will waste even crazier amounts of gas right? I dont care too much bout the gas since the most I get already is bout 12mpg but would still like to know... How much roughly would these gears cost as well?
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 09-16-2006, 02:03 PM   #50 (permalink)
kartman's Avatar
Titan trannys are geared lower than most domestics. Our trucks final drive with a 3.36 is similar to a chevy.ford etc final drive with 4.10s.
Rebar Wrangler
Old 09-16-2006, 02:29 PM   #51 (permalink)
ptgarcia's Avatar
Like Kartman said, the difference is in the transmission gearing. So Nissan had to press the fact that final drive ratio is about the same as the final drive ratio of the domestics with 4.10 gears. Just work off the stock Nissan gear ratios and ignore the whole "similar to 4.10" thing.
Pauly
Old 09-16-2006, 07:18 PM   #52 (permalink)
QShip's Avatar
After talking with more knowledgeable than me, I would prefer 3.73.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 09-16-2006, 09:24 PM   #53 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
After reading more of the thread I think I'd be down for the 3.73s and not the 4.10s
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 09-17-2006, 06:46 AM   #54 (permalink)
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
I really don't know much bout gearing, but I have this question for you gear gurus.. If I have the 2.94 now which is equivlant to the 3.73 and i want to have the bigtow gear which is the 3.36 which performs like a 4.10 if i get the 4.10 gear will it perform like a 5.20? i dunno i just know i dont want anything higher than the "stock " big tow gearing, just want more acceleration off the line at the track.
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
Toomnymods is offline   Reply With Quote
Old 09-17-2006, 10:50 AM   #55 (permalink)
ptgarcia's Avatar
What size tire are you running? 3.73's with 35" tires will have slightly lower gearing than the Big Tows 3.36:1 gearset. If you're running 33" tires, 3.73's will be even lower, probably equivalent to something like a 4.56 (I didn't do the math-I haven't had my coffee yet ).
Pauly
Old 09-17-2006, 10:55 AM   #56 (permalink)
i thought 3.73 was higher than the 3.36? the number is higher why wouldnt it be a higher gear? im confused..
BEST 1/4 Times
UpRev ECU Tuning!!
Old 09-17-2006, 11:07 AM   #57 (permalink)
ptgarcia's Avatar
Its the opposite. The higher the number the lower the gear and vice versa. When going to larger tires you want lower gears.
Pauly
Old 09-17-2006, 11:16 AM   #58 (permalink)
It's a ratio, from pinion to ring gear. For example with a 3.73 gear; for every 3.73 rotations (revolutions) of the pinion, the ring will turn 1 time. So to break it down even simpler, for every 3.73 revs of the drive shaft, the tires will turn 1 rev.
-Counsel Yourself
Old 09-19-2006, 02:53 AM   #59 (permalink)
SmokedTiresITAN's Avatar
Send a message via AIM to SmokedTiresITAN
id be down for the 3.73 or 4.10 as long as the ecu isnt an issue! my wallet is already open! changing the gears in my old z28 was the best mod i ever did.... i have been waiting for these to come out for the titan... so dont be a TEASE please :-)
Visuals:
4 piece chrome billet grill * Stillen Rollpan * 22" x 9.5" Ultra StarGazer Chrome Wheels wrapped with 22" Nitto 420S tires * Rear end lowered 2" * Blacked out tail lights * 15% tint all around with 50% tint on windshield * Keystone Good Hood
Performance:
UpRev * TB-Bypass * TB Spacer * Stillen LT Headers to High-flow cats to JBA Evol Exhaust * Volante CAI with scoop
Futures
JWT S2 Cams * Detroit TrueTrac * PS Pulleys (needs to be installed)
Audio:
4 Diamond Audio D3 10" sub-woofers powered by a Rockford Fosgate T10001bd Amp * Kenwood Excelon KVT-815 In-Dash DVD * Kenwood DV4100 Navigation with a Kenwood LZ-800W in custom mount * Infinity Kappa Perfect 6.1 6.5" Component Speakers powered by a Rockford Fosgate T3002 Amp
SmokedTiresITAN is offline   Reply With Quote
Old 09-19-2006, 06:04 AM   #60 (permalink)
QWIKWHIP's Avatar
Are they done yet? lol
