30k Mile Maintenance
I'm looking through my service manual at the 30k mile maintenance. There are two things I want to make sure I'm doing right.
First ~ Replace Transfer Case Oil (2 1/8 qts)
I peeked under the truck and I see two star shaped plugs. I'm guessing the lower is the drain and the upper (both on same side of transfer case) is the fill. Is this correct? It looks kind of tricky to fill the case. Are there any tricks or do I just use a pump or hook some tubing to the bottle and squeeze it in?
Second ~ Replace Auto. Trans. Fluid (?? qts)
I'm a little more confused with this. I've read a few threads and it looks like you can either drain it or have it flushed and at 30k miles you only need to have it drained. Is this correct? If so, where do I drain the fluid and how much is required? Anything else I need to know? Is this something other people are doing at 30k miles?
Thanks for the help!!
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
