Old 09-23-2006, 08:12 PM   #1 (permalink)
Taleen The Titan's Avatar
Front Diff Leaking Fluid (installing lift)
im in the process of installing my lift kit. when i removed the cv joints from the front differential it started leaking fluid. but when i slide the end closer to the differential it stops(you can slide it maybe 1/2in each way)and when you move it out towards the wheel it slowly dripples.. is this normal? im installing it back in tommoro so info would be appricated.thanks
Taleen The Titan is offline   Reply With Quote
Leaking Fluid-Front Right corner whiteLE Titan Problems & Dealer Service 10 06-29-2007 11:37 AM
Windshield Washer Fluid Leaking skromfols Titan Problems & Dealer Service 7 07-27-2006 02:32 PM
When to change front diff. fluid? Colorado_Titan Titan Engine, Transmission & Drivetrain 7 03-25-2006 01:50 PM
Fluid leaking, smell from Front end?? Wiscdave Titan Engine, Transmission & Drivetrain 5 03-08-2006 05:40 PM
transmission fluid leaking toadvb20 Titan Engine, Transmission & Drivetrain 23 02-12-2006 11:09 PM
