overfilled and way underfilled fluid
I need some help/advice about my situation. I recently did a tranny drain and fill but kept getting the wrong level on the tranny dipstick. So here's a quick questionaire, if you will:
A) Is overfilling the tranny by 1/2 qt a cause for concern if i only drove the truck for about 200 miles?
B) If the dipstick shows about 1.5 qts LOW (barely showing any fluid on the dipstick), should i be concerned even if i only drove it for about 30 minutes (or 20 miles)?
Now, after all my trials and error, im happy to say that im satisfied with my level... it took 4.5 qts for it to be in the OK range. Oh, and if the fluid level is right at the 'add' mark on the dipstick, it'll just take about 1/2 qt or lower to bring it up to full... (had to learn it the hard way; thought it was 1 qt needed like the engine oil but it's not). Hope this helps anyone..
Thanks for any replies..
Eric
2006 Titan SE CrewCab 4X2 Smoke, SE Popular Package, StepRails
