Old 10-24-2006, 07:48 PM   #1 (permalink)
A2titan's Avatar
Electrical whine coming from engine.
Engine off / ignition on, electrical high pitched whine coming from engine, having trouble narrowing it down. Throttle body? Anyone else heard this when the engine is off and the ignition is in the on position?
05 Smoke SE CC Big Tow 4X4, Mods: PRG 2" front-PRG 1.5" rear,PRG rear Bilsteins, Banks Exhaust, Front Air Dam, Power Tailgate lock, Fram Air Hog, Prodigy brake controller, Extang Trifecta bed cover. Bed Fade TSB performed by Rhino!
A2titan is offline   Reply With Quote
Old 10-24-2006, 09:21 PM   #2 (permalink)
TitanZX's Avatar
Send a message via AIM to TitanZX Send a message via MSN to TitanZX
Re: Electrical whine coming from engine.
Mine whines too with the ignition off.
Having a heavier duty electrical system with our Big Tow packages may have something to do with it aswell. Its normal
2007 Yamaha V-Star 1300 -
RIP: 2004 KC Titan 2WD
2008 Texas Edition GMC Sierra Crew Cab
Stereo:
Pioneer DEH-980BT deck, (F) Focal Utopia 165W, Clarion 4 channel, JBL 1200.1, (S) 2 12 inch TC Sounds TC1000's
Suspension (PRG): 2 1/2 Leveling Kit, 4" CST Spindles, PC Carrier Bearing Drop kit, PC rear shocks, 4" Blocks.
Tires: Kumho KL78 Road Venture 325/65/18's
TitanZX is offline   Reply With Quote
Old 10-24-2006, 09:24 PM   #3 (permalink)
Supporting Vendor
P's Titan's Avatar
sometimes notice it but don't think much about it.. will keep on checking out this thread for replies. Could be something ?
my mods list
USE DISCOUNT CODE FOLGER FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 10-25-2006, 03:10 PM   #4 (permalink)
A2titan's Avatar
Took the top cover off this afternoon and it's not the throttle body. Any ideas. It does stop and start when I go from acc to on with the ignition. Still can't figure out where it's coming from?
Old 10-25-2006, 03:11 PM   #5 (permalink)
walleeme's Avatar
Fuel pump electrics.
My has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES.
And if you have to, you have to.
Wallee AKA BaldWhore™
You know you had a great night last night when you make it home the next day missing at least 1/2 of your clothes.
I'm going to start up a soup kitchen. That way I can be first in line.
walleeme is offline   Reply With Quote
Old 10-25-2006, 06:21 PM   #6 (permalink)
A2titan's Avatar
Thought of that too, I hear it come up to pressure and stop. This is a high pitched electrical whine. I put a stethoscope on the fuel rails and nope. Also tried to listen in on the BCM and no there also. When I droped the scope near both right and left exhaust manifolds it got louder. This is odd. I never noticed this before only the past few weeks.
Old 10-26-2006, 01:37 AM   #7 (permalink)
Justintoxicated's Avatar
mine has had this for a long time, it's not very loud and jsut loud enough to notice if you have good ears. I know if I took it in for warranty issue they would not hear it and charge me $50 for wasting their time.
I'm almost starting to think it is the airbox.
Old 10-28-2006, 02:55 PM   #8 (permalink)
A2titan's Avatar
I need to purchase a mechanics stethoscope so I figure this out.
Old 10-28-2006, 03:20 PM   #9 (permalink)
BKW
A block of wood will work....just make sure the wood is long enough, so you won't catch your hair in the fan!
You can isolate the problem by pulling off one plug wire at a time. When you hit the cylinder that's tappin' the noise will go away.
Make sure you use a plug wire puller device....not your hand.
I'm not kidding about the wood...this trick has been around forever.
BKW is offline   Reply With Quote
Old 10-29-2006, 10:43 AM   #10 (permalink)
A2titan's Avatar
No tapping noises here. Just an electrical whine when the ignition is turned to the on position. Note, the engine is not running.
Old 10-31-2006, 04:46 PM   #11 (permalink)
Yes, i have this too on my 06 titan SE with about 21k miles. It doesnt happen all the time, but i guess occasionally during mornings. I turn the key to "on" but the engine is not starting up or running. The electrical whine sound comes on. Seems to decrease in volume, happens to be loud and gets quieter. I guess im not the only one "whew".
2006 Titan SE CrewCab 4X2 Smoke, SE Popular Package, StepRails
upshift is offline   Reply With Quote
Old 10-31-2006, 09:27 PM   #12 (permalink)
TitanZX's Avatar
I concur on the block of wood device, however I have always used a wood broom to do the trick. All in all, its the same principal.
W/ this method, I found out that my CPI fuel injection was blown on my S-10 SS a couple of years back, w/o taking the intake manifold off
Stereo:
Old 11-06-2006, 11:33 AM   #13 (permalink)
cassio's Avatar
Send a message via AIM to cassio
in for more info.... mine is doing the same, going to change the oil in a couple of weeks and will diagnose then, but id like to know if someone has found the culprit.... i hate noises!! unless its burning tires and the exhaust.
Smoke 2004 LE
Crew Cab *Big Tow Package *4x2
Armada Front Spoiler * Buggaurd
5% tint * 6000k HID + fogs
2x 12"Kicker subs w. stock rockford
261 hp, dyno-dynamics
cassio is offline   Reply With Quote
Old 11-06-2006, 06:28 PM   #14 (permalink)
Not sure how I'm going to use the broom handle trick when the truck is doing 55 or faster lol.
Don't pull the plug wires by hand?
Old 11-06-2006, 07:47 PM   #15 (permalink)
pi3yeargrad's Avatar
I have never had any whine till recently...but mine while Im driving or as long as the engine is on... Ive heard people call it "alternator whine" ...is this the same noise u guys are experiencing? I never experienced till I dropped in my new amp and components...
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Dreaded Whine ecbmxer Titan Visual & Audio Discussion 17 10-15-2007 05:31 AM
I finally cured my engine whine! ecbmxer Titan Visual & Audio Discussion 11 01-18-2006 08:08 PM
Front End Whine nthomp16 Titan General Discussion 2 12-15-2004 02:03 PM
I need help with Alternator whine DryHeat Titan Interior Discussion 45 12-06-2004 03:14 PM
check engine light keeps coming on rawze Titan General Discussion 4 09-08-2004 11:10 PM
