Old 11-02-2006, 06:55 PM   #1 (permalink)
rphowell's Avatar
diff lock
I read in the manual that the diff lock is only good up to 4 mph. Huh? Wouldn't seem to be real useful if that is the case. When I try to engage the diff lock, the light indicator just blinks. Is this engaged?
2005 Titan LE CC, 4x4, BT, OR
color: Red Brawn
options: all of them
add-ons: Zoomers exhaust, Lorado Access bed cover
rphowell is offline   Reply With Quote
Old 11-03-2006, 11:08 AM   #2 (permalink)
bucs1's Avatar
Re: diff lock
Light will remain steady when properly engagged. Diff loc light will
blink on dashboard when pressed, but not work. Stop vehicle, place
in neutral, put in 4lo(green light will appear steady) then press your
loc switch(amber light appears) and dont drive over 4mph. I know,Iknow
owners manual says so.
bucs1 is offline   Reply With Quote
Old 11-03-2006, 11:12 AM   #3 (permalink)
rphowell's Avatar
Re: diff lock
Okay. So we're not "supposed" to drive over 4 mph, but the lock will still stay engaged past that speed?
color: Red Brawn
Old 11-03-2006, 11:28 AM   #4 (permalink)
bucs1's Avatar
Re: diff lock
I have, not like a race car but alittle faster just to get unstuck.
Only 1 time did I hear a slight popping noise , but what the heck
it goes with a the other noises my 06 makes. lol. Maybe , someone
else may differ but I dont think a few mph will hurt. Then again with
all the differential problems..................hmm?
Old 11-03-2006, 02:56 PM   #5 (permalink)
rphowell's Avatar
Re: diff lock
I've tried the same procedure you mentioned for activating the diff lock and the light just continued to blink. Do you have to drive around a little to engage it?
color: Red Brawn
Old 11-03-2006, 07:15 PM   #6 (permalink)
rphowell's Avatar
Re: diff lock
Ok. I just went and tried it again. I had to wait 15-20 seconds for the light to stop blinking. And then after I turned the switch off it took about 8 seconds for it to disengage.
color: Red Brawn
Old 11-03-2006, 08:06 PM   #7 (permalink)
FuzzyLogic's Avatar
Re: diff lock
Mine does roughly the same thing. But, the delays are probably not quite as long.
The locker is not meant for extended use. It is meant for very slippery situations in sand or mud and for mainly straight runs out. Tight turns put a lot of pressure on the differential, especially when the traction is moderate to good. So, once you've gotten out of the bad stuff, you should dissengage the locker.
I'm interested in hearing about the detroit limited slip mod. I haven't seen a lot of comment about it since it was released a few months ago. True limited slip, which would require removing the locker, might be a geat alternative for overall road and off-road performance.
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
FuzzyLogic is offline   Reply With Quote
Old 11-04-2006, 08:29 PM   #8 (permalink)
pj king's Avatar
Re: diff lock
The rearend is a limitted slip all the time. The locker is a added bonus.
pj
pj king is offline   Reply With Quote
Old 11-08-2006, 08:11 AM   #9 (permalink)
trkconvert's Avatar
Re: diff lock
pj
well, not really. all Titans come with an open diff. you only get an e-locker with Off-road package. there are no limited slips on Titans
Black de-badged 2006 Nissan Titan CC LE 4WD. Mag-Hytec diff cover, TrueTrac, T-Rex Billet Vertical Grille and Bumper Insert, Sway-a-way coilovers, Total Chaos control arms, Donahoe Racing rear shocks
trkconvert is offline   Reply With Quote
Old 11-08-2006, 08:37 AM   #10 (permalink)
Banned
A-Rod's Avatar
Re: diff lock
no, he's right.. the differential goes from lsd to locker... its is actually a fairly decent lsd, too.. better than the one I had on my fronty... only non locker equipped Titans have the open diff
A-Rod is offline   Reply With Quote
Old 11-08-2006, 12:06 PM   #11 (permalink)
Re: diff lock
All Titans have an open differential. The LSD we have is ABLS and is controlled by the brakes and has nothing to do with the differential. ABLS is is disengaged when the locker is in use.
The ABLS is a gimmick and is one small step above useless. If you use the Titan like I do on a ranch, the ABLS is engaged at least 20 times a day. As a result of this I am on my third ABS unit and my rear brakes are on their third set of rotors and pads, and I only have 19k miles, with about 5k miles in 4WD.
Even when the ABLS works, it is nearly useless. The tires have to spin way to much before it engages. Even when it engages, the brakes are not strong enough to halt the spinning tire.
Nissan should have spent the money on a true limited slip.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Diff Lock light comes on chrisr400cc Titan Problems & Dealer Service 16 05-04-2007 08:06 PM
Question about 4wd Lo and Diff Lock. Jeostang Titan General Discussion 14 12-18-2005 10:36 AM
Diff Lock Indicator stays on scd325 Titan Engine, Transmission & Drivetrain 4 03-22-2005 02:49 PM
Slip/abs/diff lock lights on? djmac Titan Problems & Dealer Service 1 01-28-2005 09:36 AM
E-LOCKŪ Rear Diff. -- how is it? pluckyew Titan General Discussion 0 09-14-2004 01:24 PM
