Old 11-11-2006, 03:44 PM   #1 (permalink)
Does anyone know the Titans rear dif code?
Such as R200 for the 240SX or the R180 out of the 240Z.
Broke_as_**** is offline   Reply With Quote
Old 11-11-2006, 07:59 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: Does anyone know the Titans rear dif code?
I think this thread has the part numbers, old and new:
Here's # of Rear Diff Failures Reported
Old 11-11-2006, 09:03 PM   #3 (permalink)
Hmmm...parts numbers don't match up but then I imagine they wouldn't from vehicle to vehicle. Anyway the reason I ask is that I found this site while searchng for some VK56 info and came across a thread that indicated that Titan owners would love them some 3.73 gears long time. Then I remembered something I saw a while back on a 300ZX forum about the Titan using the same R230 rear differential as the Z32.
Z32 stock rear gear ---> 3.692
Don't know if that has ever come up or if it would even work but I was actually curious as to the opposite, the steeper Titan gears put in the back of the Z rear diff...which would be nice if...I don't know, maybe for going to the salt flats in Utah.
Also in that thread there was raised the question of 4.10 gears, which an aftermarket company has recently made for the Z.
Old 11-11-2006, 11:38 PM   #4 (permalink)
NorCal 4x4's Avatar
Titans, (5 speed automatics), come with either a final gear ratio of 2.94; similar to a 4-speed automatic 3.73 ratio, or final gear ratio of 3.357:1, similar to a 4-speed automatic 4.10:1 ratio.
Aftermarket gears will be available in the near future:
http://www.titantalk.com/forums/tita...ars-titan.html
Old 11-12-2006, 12:14 AM   #5 (permalink)
Sounds like the situation is well in hand, just figured I'd float the idea on the off chance it might help somebody.
Is it only 4 WD Titans that have rear end problems??? Tami Titan Problems & Dealer Service 2 03-31-2006 07:29 PM
Rear Shock Possibilities for Titans with 1-1.5" blocks bladas Titan Suspension 33 05-03-2005 07:58 AM
Rear Under-Seat Storage Bin for MY04-05 Titans dsstest Titan General Discussion 8 03-15-2005 04:08 PM
