Now a bigger question is there a way to prevent such failures. It does sound alarming not to be able to use 4WD when you need it for fear it may blow the diff, the axles will pop out etc. I would love to know if there is an aftermarket solution to the problem.
Black de-badged 2006 Nissan Titan CC LE 4WD. Mag-Hytec diff cover, TrueTrac, T-Rex Billet Vertical Grille and Bumper Insert, Sway-a-way coilovers, Total Chaos control arms, Donahoe Racing rear shocks
It would be nice if people would get more detailed info from the tech regarding these failures. W/O knowing the cause(s) it is difficult to think about a fix. If the housing is just weak, that is a big problem. If some internal component is weak, an aftermarket fix might happen.
There should be a Nissan solution to the problem. Why should we be paying to fix what Nissan should be fixing. First the rear, now the front.
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers
I'll be sure and provide the details, at least according to the service manager at Nissan, once they break this thing down and determine more accurately what may have caused it. I would expect as guarded service managers go, they won't do any finger pointing at the manufactuer, but maybe in this scenario he will have no choice but to blame Nissan for a design flaw.
I have heard it takes literally hundreds of cases for an auto company to consider a problem to be a design flaw, like the brake rotors being to thin and subsequently warping.
Another issue that was mentioned on the forum is front axles popping out. Something to do with C-clips?
Can someone explain why you shouldn't use 4 x 4 and pull out someone or something in reverse?
Why is this a problem for the front differential?
I believe the issues is the differential is designed to take the larger load (i.e. towing) when you are driving forward, ok to back up by yourself, just don't pull with the front and back up.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
This evening while I was driving home from work I switched over to 4hi coming off the highway and all my 4wd did was spin and sounded like the gears wouldn't catch. I used it not 2 hours before hand. DANG!!!
Let us know what the dealership tells you. I wonder if the transfer case simply didn't properly engage the front differential, or if there is a problem with the gears in the front differential.
I'm sure you were disappointed nonetheless. As rare as it is for most of us to use the 4WD, it really sucks when the occasion comes up that we can, and it fails to operate correctly.
Good Luck
Yeah, the dream scenario would be to get stuck, shift into 4x4, the front diff grenades, hook the winch cable to a tree to get unstuck, then have the winch yank the Road Armor bumper off, all while the guy in the Dodge Ram is recording the video.
Could be caused by left front carrier bearing. Many four wheel drives have play in the bearing on the left ( driver's ) side.
I started out with a bearing noise in the left front. They rebuilt the front diff. Next, it was leaking at the side seal on the front left. They replaced the seal. Next, the axle was pulling out on the front left and the diff was making some grinding noises. They replaced the front diff.
