Update: front differential and PRG kit
Thought I would post an update on my problem with the front axles poping out. First off, I will say that the PRG kit has nothing to do with the axles popping out. I took the kit off before I took it to the dealer, they replaced the circlips and the seals. I left the kit off for fear that it caused the problem. Two weeks later the axles popped out again. I was driving in the same conditions when it happened both times. On asphalt with very patchy ice. I realize that you should not make hard turns on a hard surface while in 4WD, which I didn't do. Both times I was driving on icy roads and had to make turns, the wheels hit a solid patch and POP! I get out and look and there is oil draining out. I use 4WD pretty frequently, and have never had a problem offroad, where there is some loss of traction while turning. But, when driving on-road we can't be expected to switch in and out of 4WD every time we have to make a turn. I have driven every other truck I have ever owned the same way, and never had a problem. Anyway after the second time the dealer contacted nissan and they are aware of the problem and told him to order a new front differential, and axles which are supposed to be redesigned. I be glad to put the PRG kit back on, as the truck looks pretty sorry without it. I keep every one posted of the results.
