Old 01-26-2007, 09:27 AM   #1 (permalink)
TitanTech659's Avatar
Pic of inside of transfer case
Here's a picture of the inside of the Titan transfer case. I took it with my cell phone so it's not that great and I had to make it a little bigger but it gives you an idea of the internal workings of the unit. I had to take it apart because a guy drove over a concrete block and broke the drive shaft. The drive shaft left some pieces in the transfer case so I replaced the housing and seal along with the drive shaft.
TitanTech659 is offline   Reply With Quote
Old 01-26-2007, 09:33 AM   #2 (permalink)
Re: Pic of inside of transfer case
Here's the original picture.
Old 01-26-2007, 09:34 AM   #3 (permalink)
gixxer0.6g's Avatar
Cool. That thing looks pretty stout!
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 01-26-2007, 10:51 AM   #4 (permalink)
great picture titantech, even if it is a bad one.
Hey maybe you can answer a question regarding front diffs. Nissan changed the recommendations on the rears to 75w140, but not on the front. When you service front diffs, are you putting in 90 or 140? This question was asked in another thread, i don' think i saw an answer though. Also are you noticing that factory fills for the diffs are way off? My rear was low by like 700ml. Thanks.
kman is offline   Reply With Quote
Old 01-27-2007, 07:54 AM   #5 (permalink)
The day I took that picture I didn't have my digital camera with me at work but it gives you an idea.
When we service the front diffs we put in GL-5 80-90. I suppose you can put synthetic in it and not have a problem. I haven't noticed the factory fliud levels to be low on the diffs but when we get the truck off the hauler we take it and put a couple miles on it before we do anything else. Therefor the fluid would be warmed up and is usually full. I'll have to check it before I drive it to be able to answer your question. It is possible though. I've noticed some of the cars we get in are a little low on engine oil.
Old 01-27-2007, 08:19 AM   #6 (permalink)
Cool pic, thanks. Now somebody find us some crawler gears for that thing.
transfer case lubricant REP Titan General Discussion 0 12-22-2006 09:41 PM
Transfer Case willpm Titan General Discussion 5 12-12-2006 08:45 PM
Transfer Case?? 20TITAN04 Titan General Discussion 16 02-25-2006 09:44 AM
Transfer case.. vector6 Titan Engine, Transmission & Drivetrain 2 12-21-2004 02:20 PM
Transfer case being replaced Still thinkin Titan Problems & Dealer Service 27 09-13-2004 03:35 PM
