Originally Posted by HRTKD
I'm going to go out on a very short limb here and say that there is no filter in the transfer case. I have not heard of having a filter in a transfer case before and I don't recall seeing anything close to a transfer case pan where a filter would be serviced from.
As I recall I used the RTV on the drain plug. No problems yet. I might go with teflon tape next time since it is a lot cleaner and easier to use..
The above reply and a few others like are a few months old ... but in response to it. And for those of you that would like to know ... like myself ... there is indeed an oil filter on the transfer case at least on the '04's. I used to have an '04 ... but now have an '05. The '05 does not have one. Nonetheless ... here are the directions per the '04 Service Manual:
Page 1,
Page 2
Also make note ... it says to REPLACE the three o-rings.
The above has been omitted from later revisions of the service manual.
Although I have the manual ... and have read thread after thread ... I can't seem to figure out what kind of tool I'm supposed to use to remove the t-case drain/fill plugs ... can someone please enlighten me ... PLEEEZE!
Also ... I found out the hard way when I was performing my 30K service today. I started with the front ... easy as pie. The rear ... I pulled the drain plug and maybe .25 of a quart drained out. I was like OH CRAP ... I've had no fluid for who knows how long!!!! And I've been pulling a 6000 lb boat and trailer!!! But it didn't look black ... so I was REALLY confused.
When I started to fill it back up ... I didn't even get half the bottle put in before it started overflowing ... then I was like WTF!!! I was pretty pissed off. I figured there must have been an air pocket or something that kept the oil from draining. I pull the plug again and a ton of oil pours out and there is another huge mound of sludge on the plug. So I guess it was REALLY clogged up. Fortunately I purchased enough oil to finish the job.
What's the lesson? If little to nothing comes out or even when the flow seems to be done ... make sure you stick a screwdriver or something in the drain hole before you put everything back together and then spill a bunch of your brand new expensive oil all over the concrete. That goes for the front too.
Now that I've hopefully helped someone out there ... please let me know what tool I need to use to get those plugs out of the t-case and where I can get one.
Thanks,
Jason
