Old 06-25-2008, 10:14 PM   #1 (permalink)
pedalhappy1053's Avatar
Check Engine and SLIP Light
OK, I was visiting a freind and she lives in a coldasack. ( Not sure if thats how you spell it ) I had to do a U-Turn. So I started to do it and as I was doing the U-Turn, I noticed the Check Engine Light came on. Then as I proceeded in the other direction and tried to go, the SLIP light came on. I never even got to 5 MPH. After that, the RPMs wouldnt go past 1500. I pulled over and turned off the truck and started it up right away and the same. I turned it off again and waited about 5 minutes and the SLIP light went away but the Check Engine Light didnt but I was able to drive the truck. Any Ideas?????
NEXT MOD: UPREV And Trutrac
MODS DONE: K&N FIPK Intake, Throttle Body Spacer, BANKS exhaust, 6" Pro Comp Lift, SAW Coilovers with PRG Upper Control Arms
pedalhappy1053 is offline   Reply With Quote
Old 06-25-2008, 11:22 PM   #2 (permalink)
Gonpostal's Avatar
Re: Check Engine and SLIP Light
thats weird the same thing happened to me last week when i installed my bully dog.
Mods: CST spindles, DR coilovers, PRG UCA, Bilstein rear shocks, 1.5 deavers, OR Traction Bars, 3 inch BL, N fab bars, AEM Brute force intake, Banks exhaust, Bully Dog, 18x10 Mazzi Hulks, 37x12.50 M/T Toyo O/C.(Next Mod....Gears from hoopers and Diff Cover.
Gonpostal is online now   Reply With Quote
Old 06-26-2008, 12:57 PM   #3 (permalink)
Just took it to the dealer, told me to go back in half and hour cause they are on "lunch break"
Old 06-26-2008, 01:22 PM   #4 (permalink)
baseballfanz's Avatar
Swing by an auto parts place, most of them will pull the code for free. You could also pull the code yourself
Read and Reset the Service Engine Soon (SES) light
Go here and check it, http://www.nissanhelp.com/Ownership/Common/codes3.htm
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 06-26-2008, 03:02 PM   #5 (permalink)
Just got back, they hooked up the cunsult II and they pulled a couple of codes. On of them was something to do with the gas tank for emissions. And the other code was from the engine. Both codes are tied to each other. The good news is that its under warrenty.
Old 06-26-2008, 03:17 PM   #6 (permalink)
Good to hear, probably the EVAP system.
Old 06-26-2008, 04:09 PM   #7 (permalink)
Im not too sure what that is. He said that when the gas expands it goes into a canister or something like that. I was half asleep when he explained it to me
P1027 Service Engine Soon Check engine light Hendge Titan General Discussion 0 01-21-2008 01:28 PM
service engine light and slip constantly on? ratfink1970 Titan Problems & Dealer Service 2 11-15-2006 02:21 PM
Check engine light (CEL) neilsonjr2006TITANse Titan Problems & Dealer Service 10 05-29-2006 06:49 PM
First check engine light the head Titan Problems & Dealer Service 17 08-24-2005 05:39 AM
