Old 03-06-2007, 02:13 PM   #1 (permalink)
Fix for Engine ticking
Having already tried the ground wire thing (didn't do anything at all) I went to the next step in resolving my engine tick at idle and when powering through gears (particularly between 2K and 3K). I tried Lucas oild stabilizer upon the urging of my good friend who is a gear head. Lucas oil stabilizer DRASTICALLY reduced this ticking in my truck. Overall engine smoothness is back and for 9 bucks, I can't even tell you how much better the thing sounds/feels winding out. It displaces one quart of oil for those of you unfamiliar with the product. I personally was not a believer, if it's so good why not integrate it into the oil? I'm not sure but my next venture will be a thicker oil, I'm running Mobil 1 5W 30 soon to be 10W. I will post when I have results for that.
Overall, buy the lucas and try it, you will be glad you did even if you're not having this problem in particular
2005 Titan King Cab XE with LE wheels, Falken 285's, Custom IMCO dual exhaust, tint, intake
ambiguousanomaly is offline   Reply With Quote
Old 03-06-2007, 02:18 PM   #2 (permalink)
konigfritz's Avatar
Re: Fix for Engine ticking
The mobil 1 5w-30 made mine much quieter.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 03-06-2007, 02:40 PM   #3 (permalink)
Antihero's Avatar
Oil additives are not good. They cause the oil to become aerated which reduces the lubricity. Read this http://www.bobistheoilguy.com/images/lucas/lucas.htm
You might want to reconsider lucas oil additives.
2006 Radiant Silver 4x2 CC SE with AEM Bruteforce & Magnaflow single exit exhaust
1971 Dodge Charger
Antihero is offline   Reply With Quote
Old 03-06-2007, 03:40 PM   #4 (permalink)
Krodad's Avatar
I used to be a big additive user until I saw some of the things that can happen when you mess with the chemsitry of the oil...especially synthetic oils.
I'd reconsider the move to 10w-xx oil...nothing all that wrong with it, but the 5w, or even 0w is the best choice for lubrication during initial start-up...after that, it's all in the big number...go to a 40w if you want something different, only real disadvantage is that some say your fuel economy will go down with the higher viscosity. I use 0w during the cold "half" of the year, and 5w30 or 40 for the other half...always synthetic. No Lucas stabilizer, or ptfe, or anything like that. Let the good oil do what it's supposed to do.
All that being said, I do use the Lucas in very small amounts both in a couple of my power equipment motors (splash lubricated) and a little in one of my pressure washer pumps.
Krodad is offline   Reply With Quote
Old 03-06-2007, 03:54 PM   #5 (permalink)
37L1's Avatar
Mobil 1 0W-40. . . .
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 03-06-2007, 06:01 PM   #6 (permalink)
FlimFlamMan's Avatar
Bump it up
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 03-07-2007, 11:59 AM   #7 (permalink)
Titan450's Avatar
I use Royal Purple 10w-30 and i love it. But i heard the Mobil 1 is better what is your guys's opinion?
2004 Galaxy Black CC w/ CST 4" spindle lift, Radflo front Coilovers, Fabtech Ubolts and 4" rear blocks, Bilstein 5125 rear shocks. 17x9 Moto Metal 951's w/ 315/70R-17 BFG All-Terrain TKO's wrapped around em. Bad a** setup.
Titan450 is offline   Reply With Quote
Old 03-08-2007, 02:12 PM   #8 (permalink)
Justintoxicated's Avatar
Yep... x2 I do use their Fule Injector gas treatments though.
Personaly I use amosil and Their filters. It also quiets the motor.
Old 03-09-2007, 12:46 AM   #9 (permalink)
I dunno about air in the oil, but its been a while and that engine is still smoother than ever with the Lucas, I guess if it blows up I'll drain it and claim it under the warranty. Don't think its gonna happen though. I'll definitely trade a couple horse to get a smoother better lubricated engine though. Bring on the 10W 40
Old 03-22-2007, 03:02 PM   #10 (permalink)
Send a message via AIM to Jared
How often are you changing the oil? I use regular off the shelf Pennzoil 5w30 changed every 3k with 0 issues in my truck, as well as a truck that I maintain that is my04 with 100k on the clock now.
Jared is offline   Reply With Quote
Old 03-23-2007, 09:07 AM   #11 (permalink)
update on Lucas. The thing ran smooth as glass for a couple of days, now it is just the same if not worse. Going to change the oil to the regular stuff instead of the synthetic.
Old 03-23-2007, 11:41 AM   #12 (permalink)
Why not try the 10w30? I have 5w30 mobil 1, and I have been told by the dealer that that ticking is normal, and its the injectors. Now I know that some of you have said that it is not the injectors, but EVERY SINGLE NISSAN I have had makes that noise, some louder than others.
List of cars that made the ticking noise
1987 Nissan Sentra
1987 Nissan 200sx VG30
1990 Nissan Maxima
2000 Nissan Xterra
and the newest 2004 Nissan Titan.... Still think its not the injectors?
x2thez is offline   Reply With Quote
Old 03-23-2007, 11:48 AM   #13 (permalink)
I realize and appreicate that little noises can drive us crazy. My truck ticks a little. Having sent a used oil sample in demonstrating scanty wear metals (especially compared to big 3 engines IMO), I no there is no harm.
So if it ain't broke....
Essentially Stock 2006 SE 4WD with Bilstein HD's
Security System: Glock
12glocks is offline   Reply With Quote
Old 03-24-2007, 05:30 PM   #14 (permalink)
ya it's probably just one of those things, it is however very annoying, especially when it's cold... and it came out of nowhere. One day I was like, wtf is that tick, and the rest is history.
Old 03-24-2007, 07:25 PM   #15 (permalink)
budhound's Avatar
I went to Mobile 1 5w 30 and noticed a difference. Call me crazy but it seemed like my truck ran much smoother.
'07 Titan LE CC / Radiat Silver
Purchased 4/12/2007
Sirius / Sylvania Silver Star Heads and Fogs / Lund Stainless Steel Bug Shield/MB Senna Chrome 20's / General 285/50/R20's / Keypad Entry
2* timing advance 4/14/2007
Volant CAI and Exhaust coming soon
budhound is offline   Reply With Quote
Is my engine knocking or ticking? oktex88 Titan General Discussion 19 10-18-2007 05:54 PM
My findings with engine ticking M_Dizzo Titan Engine, Transmission & Drivetrain 16 02-23-2007 07:42 PM
Engine ticking Noise elking Titan General Discussion 6 08-11-2006 06:50 PM
Engine Ticking buzzkillwill Titan General Discussion 5 02-13-2005 03:22 PM
engine ticking bbplayajs Titan Problems & Dealer Service 1 01-28-2005 08:53 AM
