Old 03-14-2007, 01:31 PM   #1 (permalink)
04 Titan White Smoke on Start up
I have a 04 Titan with 110,000 miles it just started to have a cloud of white smoke on start up every now and then. it dosesn't do it every start up. performence has not been affected HELP!
toadstitan is offline   Reply With Quote
Old 03-14-2007, 01:53 PM   #2 (permalink)
Send a message via AIM to titan dude
Re: 04 Titan White Smoke on Start up
umm 110.000 miles might have to do with it! have you done all matnece?
titan dude is offline   Reply With Quote
Old 03-14-2007, 03:33 PM   #3 (permalink)
konigfritz's Avatar
could be just a slight bit of oil sneaking past the valve seals. My has a bit when it is cold out, it runs rich for the first couple minutes, seems to be normal.
Big cloud or little cloud. White or blueish smoke and is it thick or vapor like?
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 03-15-2007, 06:24 AM   #4 (permalink)
stlblues's Avatar
Take its cigarettes away.
Give BLOOD play HOCKEY-04 Titan SE CC Off-Road-05 Honda Odyssey EX-L Res
-89 Honda PC800-99 Suzuki 500 Quadrunner
stlblues is offline   Reply With Quote
Old 03-23-2007, 08:04 PM   #5 (permalink)
Our 04 started doing this at about 5k miles; it's got 42k on it now. It's intermittent as well, but when it does it, it's a HUGE cloud. It's definitely oil. It's not reproducable so there's nothing I can get the dealer to do about it.
bigric is offline   Reply With Quote
Old 03-25-2007, 08:41 AM   #6 (permalink)
Steamguy's Avatar
Keep an eye on your coolant levels. If it drops, either gradually or intermittently for no apparent reason, take it in and have a compression test done.
Sounds like a blown head gasket to this old mechanic...
The reason you get WHITE smoke is you've got antifreeze seeping into one or more cylinders. The reason it's intermittent is that it will vary depending on how the engine was used; wether or not it was stressed hard during its last drive, and so on.
Not the best of news, but nothing's busted, and it can usually be found with a compression check. But you shouldn't let it go on; it's not good for the head to have that hot spot where it doesn't belong. Repair cost varies wildly from vehicle to vehicle depending on what has to come off to replace the set of gaskets on that side of the engine, and how easy it is to get the head off/on.
Hope this helps.
Steamguy
Old 03-25-2007, 08:58 AM   #7 (permalink)
RangerNewbie's Avatar
What's it smell/ look like?
If it's not a sickening sweet smell, and it stops when the engine is warm- you're fine- it's just the condensation boiling off.
If on the other hand it is a sweet smell- it coolant burning off- usually a leanky head gasket. Get it checked soon and keep an eye on the coolant level.
If it's a bluish/ dark smoke- your engine is burning oil- possibly blow-by past the piston rings.
2006 Titan 4X4 Off-Road w/ Tow package- Stock
1997 Ford Ranger 4x4 - Slightly Modified
http://www.cardomain.com/id/RangerNewbie
RangerNewbie is offline   Reply With Quote
Old 04-25-2007, 06:57 PM   #8 (permalink)
the usual signs of a blown head gasket:
  • bubbles of air coming up into your radiator (remove cap before starting),
  • leaking radiator,
  • milkshake colored oil,
  • overheating,
  • rough running,
  • coolant or oil running from head,
  • spark plug(s) that have a green tint (if green coolant), white colored or sweet smelling exhaust.
dew08 is offline   Reply With Quote
Old 04-25-2007, 08:16 PM   #9 (permalink)
Dorsey's Avatar
smoke color is pretty subjective, although if it is indeed white it does sound like water in the combustion chamber. You should notice it needing some antifreeze if it is a headgasket. If so, do not let this go if you have changed to green antifreeze - it is death for aluminum cylinder heads. Also, you will likely ruin an O2 sensor fairly soon no matter what antifreeze you have.
Alternate explanation - Your truck has elected a new Pope.
Dorsey is offline   Reply With Quote
White Titan with white powder coated rims??? Frosty_Power Titan General Discussion 22 10-20-2006 05:59 PM
Blue smoke at start-up motoman Titan General Discussion 5 12-04-2005 06:19 PM
White smoke pouring out rear fenderwell... loufish Titan General Discussion 5 10-27-2005 12:14 PM
Another Titan With Blue Smoke At Start Up!!! Mine!!! HEMI-SMOKER Titan General Discussion 23 08-19-2005 11:58 AM
OMG - Blue Smoke at Start-up HDVa Titan General Discussion 33 08-22-2004 01:15 PM
