Old 03-15-2007, 06:31 AM   #1 (permalink)
helomech's Avatar
slip light
I started noticing yesterday that my slip light hasn't been flashing. Our road is very slick right now I even slid into the ditch on the side of the road this morning and never saw the slip light. I engage the 4wd to get out of the ditch and still never saw the slip light. The light does come on when I start the truck. It used to flash alot on our road when the road was wet, but in the last 2 days nothing. Anyone have any ideas?
helomech is online now   Reply With Quote
Old 03-15-2007, 07:23 AM   #2 (permalink)
loufish's Avatar
Re: slip light
Any chance that you're spinning both wheels...Slip light only comes on when one wheel spins.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 03-15-2007, 07:27 AM   #3 (permalink)
Kronos1965's Avatar
Re: slip light
He's right.
SLP light comes on at startup as a diagnostic check.
Under driving conditions, the SLP light comes on when one wheel is spinning significantly more than the other and then your VDC would kick in to reduce that extra spinning. It may activate so that your SLP does not come on...
Kronos1965 is offline   Reply With Quote
Old 03-15-2007, 07:29 AM   #4 (permalink)
helomech's Avatar
Re: slip light
They seem to be both spinning, but that is kind of unusal in itself. I do have new tires, I got ride of the stock and got toyo m/t's. I might go ride some more to see if I can make it flash. Btw I don't have VDC.
Old 03-15-2007, 07:42 AM   #5 (permalink)
helomech's Avatar
Re: slip light
Just went driving through some mud on my property and never got the slip light to flash. I gave up and then saw a old tree stump and put one back tire in front of it and finally got the slip light to flash. So it is working, but it used to be real easy to get it to flash. It just seemed unusual to drive through 3 miles of wet red dirt road and not get any flash from the slip light.
Old 03-15-2007, 07:57 AM   #6 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Re: slip light
i hadn't noticed my slip light until this winter, this if my first 4wd that i've owned personally so i'm learning a little.. the slip light only came on when i was playing in 2wd on some iced/snowy roads trying to fishtale.... it let little slips go, but when i got to major slippage it flashed me "put me in 4wd dumbass "
my dad lovingly refers to all dashboard indicators as "idiot lights"
2* | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is offline   Reply With Quote
SLIP light question... Quad T Titan General Discussion 40 02-12-2007 09:54 AM
Not seeing the slip light when spinning Biscuit'sTitan Titan General Discussion 17 02-06-2007 07:40 PM
VDC off and SLIP light illuminated marc.krueger Titan Problems & Dealer Service 3 11-13-2006 12:50 AM
SLIP light staying on imjustdamngood Titan General Discussion 6 10-19-2006 12:40 PM
SLIP light in dash comes on dooboy2112 Titan Problems & Dealer Service 6 08-30-2005 08:56 AM
