Old 03-20-2007, 05:20 PM   #1 (permalink)
synthetic oil break in???
Hey guys, I'm due for my 1st oil change right away and wanted to start using mobile 1 synthetic but I was told that it is not good to use synthetics until about 10,000 Miles have been put on the engine so it can break in properly. My Nissan dealer told me I could use it right away?? Any opinions/suggestions? thanks!!
Mike422 is offline   Reply With Quote
Old 03-20-2007, 06:41 PM   #2 (permalink)
Shane06fl's Avatar
Re: synthetic oil break in???
Use it right away.
http://www.bobistheoilguy.com/
good info at that site.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 03-20-2007, 06:55 PM   #3 (permalink)
Some of the fastest, highest revving engines in performance cars come with Mobil 1 from the factory. Start using synthetic whenever you want to.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 03-21-2007, 03:46 PM   #4 (permalink)
I have a 2004 Titan and have ran Mobile 1 ful syn in it from the start and have had no trouble
89harley is offline   Reply With Quote
Old 03-22-2007, 08:00 AM   #5 (permalink)
TTfan-adik's Avatar
The main issue with breaking in an engine with synthetic oil is the piston rings. The extra lubricity can prevent the rings seating properly, or period, for that matter (about the only thing left in the engine that needs breaking in nowadays). But, it has been common practice to change the break-in oil after 500 to 1000 miles after rebuilding. So, you should be fine after the first or second oil change.......
TTfan-adik is offline   Reply With Quote
Synthetic oil c1971tra Titan Performance Modifications 18 07-01-2007 07:25 AM
Synthetic oil when new markith Titan General Discussion 5 09-01-2006 10:12 AM
when to put in synthetic? Yellomantis Titan Engine, Transmission & Drivetrain 6 05-20-2006 02:43 PM
Synthetic Oil hershman3 Titan General Discussion 28 11-04-2004 09:31 PM
Synthetic Oil? duks4u Titan General Discussion 5 03-10-2004 11:32 AM
