Old 03-23-2007, 02:08 PM   #1 (permalink)
RB's Titan's Avatar
Nissan Differential oil after 27K w/TruTrac
Hey guys just wanted to show off the Nissan Fluid after 27K of use in the rear diff combined with the Trutrac. Looks pretty good. But did go ahead and swap out to Royal Purple today.
I did find some shavings in the oil but this was what I would consider normal break in. Since it has not been opened since the install. The 3.36 gears and trutrac coupled with the OEM aluminum fin cover seem to be working well at this interval.
I sent the diff oil to blackstone to see if they would analyze it for moly and metals. I also sent in my engine oil (mobil1 puresyn) after 4K which looked a bit darker than these pictures.
nissan-differential-oil-after-27k-w-trutrac-nissan-diff-oil-after-27k-trutrac-2sml.jpg  nissan-differential-oil-after-27k-w-trutrac-nissan-diff-oil-after-27k-trutracsml.jpg
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 03-23-2007, 02:21 PM   #2 (permalink)
Re: Nissan Differential oil after 27K w/TruTrac
Looks very good to me.
Old 03-23-2007, 02:40 PM   #3 (permalink)
What is the consensus on the best diff oil to use? I am about to change the fluid on my 2006 4X4 (it is at 19,500 miles) and has the electronic locking diff.
Do I have to use any kind of special oil or like a friction modifier like some Jeeps with TracLoc need?
What have the fine folks here at TitanTalk used?
Trick is offline   Reply With Quote
Old 03-23-2007, 03:32 PM   #4 (permalink)
No additives needed. 75-140 synthetic (Mobil 1, Amsoil, Royal Purple . . . .)
Old 03-23-2007, 07:58 PM   #5 (permalink)
RB's Titan's Avatar
Chose any synthetic brand you want of the 3 listed above. If you have 3.36 gears and no trutrac I would change your diff fluid every 35K (Normal driving no towing). If towing frequently I'd change 25K....just my opinion though.
Randy
Old 03-23-2007, 11:04 PM   #6 (permalink)
Titan R's Avatar
Send a message via AIM to Titan R
Nice info! Make me want to do a complete flush soon.
PMed you Sir!
stOOpidFast
Fast-Turbo.com
TFRC RsR
4drTypeR retired...
454whp@18psi pumpgas 11.5 @ 127 spinnin slicks
527whp400tq@22psi C16 (blew it running an 06 gxsr1000!!!)
Titan R is offline   Reply With Quote
Old 04-09-2007, 03:10 PM   #7 (permalink)
RB's Titan's Avatar
Just got back the diff oil report. Seems it's doing great the combo of aluminum cover 75/140 oil and tructrac with the 3.36 gear. Here's what blackstone says.
nissan-differential-oil-after-27k-w-trutrac-nissan-syn-diff-oil-after-27k-trutrac-d01895.jpg
Randy
Old 04-09-2007, 03:13 PM   #8 (permalink)
Outstanding !
Old 04-09-2007, 03:28 PM   #9 (permalink)
RB's Titan's Avatar
I thought so too. Goes to show you that the oil is good when matched with quality parts. Just so much heat it can handle and fails. Hopefully Nissan/Detroit reads this.
So YES it is possible that you can have a good solid rear end. I beat this one really good and it's getting a little more than it ever thought it would right now.
Randy
Old 04-09-2007, 03:29 PM   #10 (permalink)
RB's Titan's Avatar
My next worry is the gear set itself...????
Randy
Old 04-09-2007, 05:53 PM   #11 (permalink)
Delta15's Avatar
Ive been thinking about getting a TrueTrac, are you happy with yours?
How does it perform in the rain w vdc on/off?
Delta15 is offline   Reply With Quote
Old 04-09-2007, 07:57 PM   #12 (permalink)
RB's Titan's Avatar
Love it and I don't have VDC. I'm a rear wheel drive kinda guy. In the rain in very specific instances you can apply enough gas to spin you around while cornering. Obviously one will need to know to turn into the skid should it happen. Other than that I happier than pigs in the mud and I got a street truck...LOL
5 star rating.
Randy
Old 04-10-2007, 08:57 PM   #13 (permalink)
silverbeast's Avatar
Question Re: Nissan Differential oil after 27K w/TruTrac
hey rb, what brand of gear oil is that in the pic's? it looks good!!
**06 TITAN CC SE 4X4 BIGTOW**
**FLOW MASTER**
silverbeast is offline   Reply With Quote
Old 04-10-2007, 09:16 PM   #14 (permalink)
RB's Titan's Avatar
It was Nissan Synthetic 75/140....it was good. But only as long as it's not getting cooked.
Randy
Old 04-10-2007, 09:20 PM   #15 (permalink)
TitanBlue's Avatar
"Hey guys just wanted to show off the Nissan Fluid after 27K of use in the rear diff combined with the Trutrac. Looks pretty good. But did go ahead and swap out to Royal Purple today."
RB beat me to it!
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Nissan Titan-NHSTA REPORTED FAILURES-of powertrain:driveline:rear differential unit: whiteLE Titan Problems & Dealer Service 619 Yesterday 07:53 AM
TruTrac?? 1BadTitan Titan Performance Modifications 26 08-20-2008 10:14 AM
Those with TRUTRAC install....... g356gear Titan Performance Modifications 4 12-28-2006 07:07 PM
Trutrac where and what lghtnquik Titan General Discussion 3 10-05-2006 08:58 PM
Front Differential Problem w/ NO help from NISSAN AlaskanTitan Titan Problems & Dealer Service 14 01-03-2006 10:58 AM
